Custom Supports
Guys just a quick one, am i right in thinking for any support enforcers to show up i need to also have support enforcer for the first ??? defined.
What im seeing is if i add custom support the normal way by only having auto generate supports they never appear ?
thanks
Postato : 29/10/2020 9:24 am
RE: Custom Supports
I'm not following ... but first you place an enforcer(s). Then you enable them.
Alternatively, you can enable enforcers, then place them.
Questo post è stato modificato 6 years fa 2 tempo da --
Postato : 29/10/2020 8:53 pm
RE: Custom Supports
As a future note: the supports only need to touch the surface that is to be supported. You can place a smaller box around the trigger and the supports will still generate. 2.3.0 Alpha has paint on support enforcers. Well worth the price of admission.
Postato : 30/10/2020 6:28 am
