Custom Supports
Littleted
(@littleted)
Custom Supports
Guys just a quick one, am i right in thinking for any support enforcers to show up i need to also have support enforcer for the first ??? defined.
What im seeing is if i add custom support the normal way by only having auto generate supports they never appear ?
thanks
Publié : 29/10/2020 9:24 am
RE: Custom Supports
I'm not following ... but first you place an enforcer(s). Then you enable them.
Alternatively, you can enable enforcers, then place them.
Ce message a été modifié il y a 6 years 2 fois par --
Publié : 29/10/2020 8:53 pm
TheMadJedi
(@themadjedi)
RE: Custom Supports
I added some custom supports to a model i was printing to support the trigger, it was added but not as large as I wanted it didn't cover the whole trigger. I enlarged the custom support area and this time the supports where generated the way I wanted
Publié : 30/10/2020 6:20 am
RE: Custom Supports
As a future note: the supports only need to touch the surface that is to be supported.  You can place a smaller box around the trigger and the supports will still generate. 2.3.0 Alpha has paint on support enforcers. Well worth the price of admission.
Publié : 30/10/2020 6:28 am
