RE: Corroded wire to heat bed
Looks like there are some bad cables out there:
@Admins: Please forward this information to QC department. So far it looks like some cables are bad crimped by the factory and causing this issue.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
If your cable is long enough, crimp on a new connector. You can also run a new wire - and crimp on two connectors.
Just do a better job than the factory did.
I also suspect Support would send you a new cable - but I would just make my own.
thanks for the help
electro-chemical corrosion caused by different elements connecting each other (for example stainless steel and aluminium -> a result is the white Aluminiumoxide).
The result of the chemical process is increasing resistance, heating up the contacts, melting the ports - Carsten
@umaker
At least I learn something when these errors happen! thanks for the description that makes lots of sense.
