ColorPrint website
JMcK
 JMcK
(@jmck)
ColorPrint website
It would be really nice if the instructions on the ColorPrint website would make clear whether the color change occurs at the start or end of the specified layer.
When someone asks you if you're a god, you say, "YES!"
Veröffentlicht : 28/03/2019 11:55 pm
Re: ColorPrint website
Colour change starts at the beginning of the chosen layer
I use Slic3r 1.42.0 beta which includes a colour change facility built in.
Veröffentlicht : 29/03/2019 12:00 am
Texy
 Texy
(@texy)
I used it for the first time last night and also made the wrong assumption. It was only a simple name plate so no big deal and got it right the second attempt (chose the next layer). However Once slight concern is that after the question is asked about correct filament loaded prior to resuming the print, it insists on extruding a tiny bit more, which could of ruined the print. Luckily I managed to grab it with the tweezers before it resumed printing. This was done whilst the print head was making its way back to position. Why does it do that, and can it be stopped?
Texy
Veröffentlicht : 12/04/2019 2:53 pm
Hi Texy,
the trick is to resist pulling the worm cast off the extruder, instead just hold on to it, click the button, and the extruder squirts the final prime out, then moves off to continuethe print, and you are left holding ALL of the waste...
Veröffentlicht : 12/04/2019 3:20 pm
Texy
 Texy
(@texy)
Yeah, but, from memory, and I could be wrong on this, the final extrusion prior to printing is done at the same time that the head moves back into position........
Text
Veröffentlicht : 12/04/2019 4:31 pm
Mj
 Mj
(@mj-2)
It does. So, when it squirts out the coil and asks if the filament is good I put my needle nosed pliers on the coil of filament and press yes with my other hand. The head will squirt out that last cm or so which USUALLY gets grabbed by the coil tail. If not my pliers are ready to make a grab. The trick is anchoring the coil so it doesn't get blown to the side by an enthusiastic fan.
Veröffentlicht : 13/04/2019 1:44 am
Text
if you are holding the wormcast when you push the button to continue, the last squirt is still attached to it, and pulls off the extruder as the extruder reverts to the printing area.
Veröffentlicht : 13/04/2019 8:24 am
