Cleaning powder coated sheet
Hello,
I recently bought a Double-sided Powder-coated PEI Satin Spring Steel Sheet and I read in the description that you can't clean it with acetone, but instead use IPA. I currently don't have a bottle of isopropyl alcohol at home, but I do have methyl alcohol. Can I use that to clean it?
I've searched for an answer on the Internet but I can't find anything about it
Thanks in advance
RE: Cleaning powder coated sheet
is that denatured spirits or methylated spirits?
if so it should be ok...
BUT. I just wash mine!
Thanks for your answer Joan,
I'll check it out, and yeah if not I'll just wash it to.
Regards Elias
