Changing to .25 nozzle Slic3r
Vegas Pay LLC
(@vegas-pay-llc)
Hello,
I wanted to try using .25 nozzle but changing the size at extruder in printer settings from .4 to .25 seems to not be the way to do that. I think I am getting a message saying it cannot be sliced because the nozzle diameter value is invalid.
Does anybody know what the problem is and what I was supposed to do so it doesn't happen?
Thank you
Opublikowany : 16/03/2019 8:36 pm
Re: Changing to .25 nozzle Slic3r
You need to set valid extrusion widths under print settings as well as changing the extruder diameter under printing settings. Hint: if you create a print settings profile with extrusions widths to 0, it will calculate valid extrusion widths at slicing time.
I've got notes on creating Slic3rPE profiles for different nozzles
here
Opublikowany : 16/03/2019 8:46 pm
Vegas Pay LLC
(@vegas-pay-llc)
Thank you. That is helpful because free time when I am not working is rare. It looks like you gave me exactly what I need to know.
Opublikowany : 16/03/2019 10:16 pm
