Changing and saving default nozzle and bed temperature settings.
The PLA I am using needs a hotter nozzle and bed than the defaults set in my printer. Try as I might the only way I can print with this spool of PLA is to tell the printer I am using PET to get adhesion but I believe I could do so at lower temperatures. I know I can do this in Slic3r, but I want to use my SD card in the stand-alone printer. When I tried changing the temps in Slic3r and loaded the g file onto my SD card and ran the print, the printer over-rode my revised temps and used the ones in the printer's default data. I am sure this has to be an easy fix, but I have not found it yet.
R. Hardy
Veröffentlicht : 02/12/2019 1:17 am
