Change X axis length for different extruder
Hi folks,
I changed my extruder to a flexion build. I am now failing on the X axis belt test. It looks like this extruder ends up being a bit wider than the stock extruder. I am assuming the failure is coming from this extra extruder width. How can I go about changing the X Axis in the firmware to get this extruder to pass. If there are other potential causes feel free to point them out. I have checked Zip Ties, screw tightness, belt tightness, belt alignment.
Thanks for the help,
Postato : 13/12/2022 4:22 am
