Change port for Termistor on the Einsy Board.
BastiBT
(@bastibt)
The previous owner did change the port for one senor from the right to the middle, because the right port was not working anymore. Me not knowing that did a firmware upgrade with the result that there is a thermistor error...
Can anyone help me out here? It seems the port can be re-addressed, but I am not a programmer, and have no experience with source code and compiling, etc.. I would like to print something until I get a new board, and am stuck... I guess I need the sensor port in the firmware changed to the middle port, and all should be fine (until a new firmware upgrade)?
PS: Printer was working fine until I did attempt the update. Otherwise I would have not realized that the issue is as described above.
Publié : 28/03/2024 11:12 pm
Robin
(@robin)
mh, with no experience with source code and compiling this will be a challenge. But with some help of an AI like GPT you might be able to pull it off...
The firmware and a build instructions can be found here: https://github.com/prusa3d/Prusa-Firmware
Look at pins_Einsy_1_0.h for pin assignment. Modify, build and flash... What could possibly go wrong?
Ce message a été modifié il y a 2 years par Robin
Publié : 29/03/2024 1:21 pm
BastiBT
(@bastibt)
RE: Change port for Termistor on the Einsy Board.
Thanks for the hint. I did get it to work - took me long enough, but the result is a working unit (for now until a new firmware is installed).
Had to change
from
#define TEMP_0_PIN 0 //A0
to
#define TEMP_0_PIN 1 //A0
Publié : 29/03/2024 2:50 pm
1 personnes ont aimé
