Catastrophic clog
jholmes15
(@jholmes15)
Catastrophic clog
Newish i3 user, this is about our 10th print. Absolutely catastrophic clog.
I have no idea how to remove this, disassembly, heat it and burn it out, could really use some help.
Postato : 24/01/2023 3:16 pm
RE: Catastrophic clog
That's not a clog.  That's a part detaching from the print bed and is caused by not enough bed adhesion.
There are probably over a hundreds threads on here with similar tales of woe.  All of them have the same advice in.
For example https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/recommendations-for-removing-a-massive-filament-blob-from-hotend/
or https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/when-a-print-goes-really-bad/
or https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/first-print-failed-catastrophically/
Anyway you hopefully get the point.  While the forum search is crap, googles is not.  "site:forum.prusa3d.com blob of doom" gets you lots of hits.
Postato : 24/01/2023 3:23 pm
