Can’t remove previous print image from bed.
I can’t seem to clean off images from previous prints. I don’t have problems with adhesion or anything else. Just a cosmetic problem. On flat prints you can see that image. What’s the trick to remove it?
Publié : 15/10/2023 1:52 am
It seems to be a side effect of restricting the heat flow beneath the print causing slight migration of the glue holding the smooth sheet to the plate. It reduces over time and is much reduced on older print sheets.
Flipping the sheet and using the other side for a while gives the sheet time to recover a little.
Publié : 15/10/2023 8:44 am
