Cant pass a self test other issues after months of successful printing
richard.j13
(@richard-j13)
after playing with a ton of different config settings I wanted to get back to the factory presets for the following reasons.
1. The printer can not locate home
2 during a print at random times.The printer will give a crash error  (for no apparent reason)  on restart the tool head goes to random positions than when the print restarts the nozzle nowhere even close to the correct location,
3. I am unable to pass a self-test even though I can pass an XYZ calibration i get an error on
4. keep getting an error msg that the MMU is not working  _ disabled.
I have attached the logs i copied from Pronterface and pasted into note++ . please let me know if there is any additional info I can provide.
Thank you in advance
Rick
Publié : 17/07/2019 4:35 pm
RE: Cant pass a self test other issues after months of successful printing
Hi Rick,
the Mk3 and Mk3S use virtual endstops,, so if the motor see's (electronically) some resistance to movement, it sometimes sets a false home position for that axis.
Can you please ensure that both X and Y move smoothly for the full extent of their travel.
are you sure you sure that you have the correct version of firmware installed?.
Publié : 18/07/2019 12:32 am
