Can't finish wizard X axis can move using manual controlls
Hi all,
I can't finish the wizard when I start my printer, the X motor moves once and the entire wizard stops saying it X axis test failed. I thought it would be the motor but if I skip the wizard and go manually move it using the menu controls I can move it. What should I do?
THanks
Napsal : 19/06/2020 10:15 am
