Calibration works, but wont print after middle calibration point scan
I have a problem with my mk3s printer..
The printer calibration works fine. The xyz calibration plus the first layer prints without problems
But when i print from sd card, the printer stops at the middle calibration point and forces z calibration itself... And after done it tries again, and again gets stuck at the center calibration point in the heatbed and this infinitely repeats itself.
I already thought it could be a damaged pei sheet, so i replaced it. Its now super smooth and looks like new.
But the same error remains. Also upgraded the firmware, calibrated again and i remain to have the same problem.
Help would be appriciated! 🙂
RE: Calibration works, but wont print after middle calibration point scan
Hi ,
Could be something with the belt tension being to slack.
I think i had something similiar .
The belt was too slack .
