Calibration not possible after crash
fabian.s4
(@fabian-s4)
Hello everyone,
I have a serious problem with my MK3. I wanted to print something as usual but decided to cancel the print after a few seconds because I forgot something. The printer was exactly at the first calibration point when it stopped. I used octoprint to stop it. After a few seconds I restarted the print, the printer did his XY calibration and was going down for the first Z calibration and rammed right into the print bed. He did not detected the crash and I turned it off after a few seconds.
I noticed that the two Z-Axis motors were at different positions and the whole X axis was at an angle. So I performed the XYZ calibration. After finishing the XY part, the printer told me that a calibration is not possible or something like that and stopped. So I started the complete calibration wizard. But during the second bed calibration point (where you have to put a paper sheet on the bed) he touched the bed after a couple of moves. The steel sheet was removed. This was not a problem for the first point.
Any suggestions on how to fix that? Or what the problem could be?
Opublikowany : 08/11/2018 3:55 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
Re: Calibration not possible after crash
try restoring to factory defaults
Opublikowany : 09/11/2018 1:30 am
fabian.s4
(@fabian-s4)
that did not help. Now he is touching the bed already when performing the first calibration point 🙁
How does he know how high he is above the bed? Is that done with the sensor on the side? Can I check if it has the right hight and is working properly?
Opublikowany : 13/11/2018 1:02 pm
Mustrum Ridcully
Time to contact the 24/7 help chat folks at PRUSA
go to a shop page at https://shop.prusa3d.com/en/
and click on the { Chat Now } box in the lower right corner
Opublikowany : 13/11/2018 6:25 pm
