Calibrating Z issues
Sandi
(@sandi)
Had my Mk3 since December, ran like a charm, no issues, then 2 days ago everything was a mess.  Tried Calibrating Z and got this....in the video, also XYZ Calibration is not working as well.  Need some help as I am at a loss what to look at to fix this.  Video attached. Thanks.
Publié : 01/07/2019 12:36 am
Sandi
(@sandi)
RE: Calibrating Z issues
https://drive.google.com/file/d/13kCnYzpY2uoEbI1mt6s65K5lWADpkeoT/view?usp=sharing
Publié : 01/07/2019 12:38 am
Dave Avery
(@dave-avery)
no video ....
Publié : 01/07/2019 1:50 am
A problem with the X or Y axis not homing correctly.  Check for cable ties preventing the X from going far left.  Also a full FACTORY RESET with DATA CLEAR has been needed when the xyz cal fails.  Printer sometimes gets a bad code in EEPROM and messes up cal constants. Reset then run the wizard.
Publié : 01/07/2019 8:27 am
lindharin
(@lindharin)
Maybe double check the PINDA sensor height too?  After a nozzle change the other day, I did a Z calibration and the nozzle scrapped the bed.  After some checking, I realized that the PINDA had moved higher.  Went back and followed the instructions in the PreFlight check of the installation instructions, and that fixed it.
Publié : 01/07/2019 8:39 am
