Burnt PLA and blown prints
ArrayElement
(@arrayelement)
My prints have been failing. One common thing I see is that there is a section of the print where the PLA is black / burnt. What causes this black / burnt area?
Opublikowany : 13/03/2020 11:00 am
rmm200
(@rmm200)
RE: Burnt PLA and blown prints
A picture would help. Burnt chunks on the print usually come from debris falling off the hot end - not from the nozzle.
Keep the hot end brushed clean and look for leaks under the nozzle.
Opublikowany : 13/03/2020 4:36 pm
Also remove the front extruder cover and inspect between the heatsink fins and heater block. If filament is oozing there, you've got a poor seal between the heatbreak and nozzle.
Opublikowany : 13/03/2020 4:57 pm
