Bump in the PEI sheet that came with my MK3S
Kyyrbes
(@kyyrbes)
I tried to contact Prusa a week or so ago and haven't received any response yet. I have just recently received my MK3S kit and the build and setup went well. the issue is that the steel sheet I received has a very noticeable bump in it that causes a large portion of the print plate to be unusable.
Will I have to buy a new one to get a good sheet? Anyone else have notable bumps on their sheets due to manufacturing error?
I took a few photos here. https://photos.app.goo.gl/C1qs24myTxLDz5iJ6
Publié : 25/03/2019 8:03 pm
Re: Bump in the PEI sheet that came with my MK3S
Try contacting support via the online chat system. Log into the online store and contact them there.
Edit: In the meantime, flip the sheet and see if that bump works its way out after a few days. The PEI is fairly resistant to bumps and dings so long as the surface isn't permanently damaged.
Publié : 25/03/2019 8:30 pm
Kyyrbes
(@kyyrbes)
Just to be clear the bump is an extrusion so I'd need to grind it down if I were going to get it to lay flat on that side.
I'll try contacting them again, thanks!
Publié : 25/03/2019 8:38 pm
