Bondtech mosquito upgrade - temperature issues with CPE
Corneliu
(@corneliu)
Hello everybody,
I have just installed the Bondtech Mosquito on my Prusa i3 MK3S+ and it looks like it has temperature problems.
I am trying to print CPE with a 0.2mm nozzle.
At 275 degrees nothing comes out and at max 295 it looks like a very thin spiderweb impossible to scratch from the steel sheet.
Does anyone had these issues?
Should I get a 50W heater cartridge?
Publié : 16/06/2021 10:38 am
Membre
RE: Bondtech mosquito upgrade - temperature issues with CPE
I do not think this is a temperature issue and I do not think a new cartridge is going to fix the issue.  Did you perform a PID calibration?
Publié : 16/06/2021 11:02 am
Corneliu
(@corneliu)
@cwbullet
Yes, I did
Publié : 16/06/2021 11:06 am
Corneliu
(@corneliu)
@cwbullet
It also takes many retries to load the filament. I mean I have to answer 7-8: no it does not show the correct color.
I shrewd in the knob of the extruder quiet tight. When I hold it with my hand I feel it working very well.
I also uninstalled the nozzle to push the filament through the hotted to see if there are any issues with the PTE tube.
Publié : 16/06/2021 11:13 am
Corneliu
(@corneliu)
Sorry for the misspelling.
Publié : 16/06/2021 11:23 am
Corneliu
(@corneliu)
Problem Solved!
I had to turn up the Flow Rate to 275%. The print is incredible accurate in comparison to the ones before.
Ce message a été modifié il y a 5 years par Corneliu
Publié : 16/06/2021 10:05 pm
Corneliu
(@corneliu)
Publié : 16/06/2021 10:10 pm
Kai_1908
(@kai_1908)
Membre
Did you change the firmware on your printer with the upgrade?
https://www.bondtech.se/knowledge-base/firmware-updates-for-prusa-i3/
Since the ESteps changed, that might be the root cause of your problem.
Publié : 20/06/2021 8:15 pm
