Bondtech mosquito upgrade - temperature issues with CPE
Hello everybody,
I have just installed the Bondtech Mosquito on my Prusa i3 MK3S+ and it looks like it has temperature problems.
I am trying to print CPE with a 0.2mm nozzle.
At 275 degrees nothing comes out and at max 295 it looks like a very thin spiderweb impossible to scratch from the steel sheet.
Does anyone had these issues?
Should I get a 50W heater cartridge?
RE: Bondtech mosquito upgrade - temperature issues with CPE
I do not think this is a temperature issue and I do not think a new cartridge is going to fix the issue. Did you perform a PID calibration?
@cwbullet
Yes, I did
@cwbullet
It also takes many retries to load the filament. I mean I have to answer 7-8: no it does not show the correct color.
I shrewd in the knob of the extruder quiet tight. When I hold it with my hand I feel it working very well.
I also uninstalled the nozzle to push the filament through the hotted to see if there are any issues with the PTE tube.
Sorry for the misspelling.
Problem Solved!
I had to turn up the Flow Rate to 275%. The print is incredible accurate in comparison to the ones before.
Did you change the firmware on your printer with the upgrade?
https://www.bondtech.se/knowledge-base/firmware-updates-for-prusa-i3/
Since the ESteps changed, that might be the root cause of your problem.
