Blockage of Nozzle or PTFE (again and again)
Acanis
(@acanis)
Hey,
its the 3rd time I try to print this: https://www.thingiverse.com/thing:2594296
After 12h it stopped before a few minutes, watch this video:
https://forum.prusa3d.com/wp-content/uploads/2021/01/PXL_20210107_073156131.mp4
The first times happend with >35 degree in my cabinet, so I thought it was because of this. But the door was open and the temp was fine this time.
I printed Prusament PLA with 210 degree.
  • How can I prevent this?
  • And can I fix/finish the print somehow? 🙁 (its just paused yet)
Thank you 🙂
This topic was modified 5 years temu by Acanis
Opublikowany : 07/01/2021 7:41 am
Acanis
(@acanis)
RE: Blockage of Nozzle or PTFE (again and again)
And I tried to move the extruder, I was able to extrude something and stopped the pause. The went back to this wrong height and didnt extrude anything...
Opublikowany : 07/01/2021 7:59 am
Reiner
(@reiner)
RE: Verstopfung der Düse oder des PTFE (immer wieder)
@acanis
Hallo,
mir geht es genau so. 2x nach 24h und 5x nach 12h, ist die Düse verstopft.
Aber Prusa will davon nichts hören.
Opublikowany : 07/01/2021 8:07 am
Swiss_Cheese
(@swiss_cheese)
Hi acanis,
It looks like your under extruding, then nozzle is clogging, based on what you mentioned in your post I'm guessing your not printing the prusament hot enough, try printing the Prusament PLA profile with the nozzle temperature set to 220C after the first layer, and leave the cabinet door open.
Good luck
The Filament Whisperer
Opublikowany : 08/01/2021 12:13 pm
1 ludzie polubili
Acanis
(@acanis)
I had a chat with prusa support and he said "under extruding", too... Seems to be a problem of this object, its lot of small "extruding-retracting"'s and I have to speed up the printing on this part of the model to increase the extruding flow...
Cabinet door was open, but I want to close it 😛 I bought a fan for my cabinet and will experiment a little. Fans are not perfect for PLA, but its printer is still too loud to always open the door.
Opublikowany : 08/01/2021 12:22 pm
Reiner
(@reiner)
Wozu dient dan die Einstellung „Ultradetail „ oder „Adaptiv“ , wenn der Drucker das nicht schafft ?
220 Grad habe ich auch schon versucht.
Opublikowany : 08/01/2021 4:46 pm
Reiner
(@reiner)
Fehler behoben. Es ist eindeutig, der ab Werk eingebaute, zu kurze PTFE im Hotend.
Benutzt den mitgelieferten, etwa 2 mm längeren aus der Reservetüte. Ich habe mir selbst aus besseren Schlauch die längeren hergestellt und seit dem drucke ich bis 0,07 herunter. Andstandslos, mehrere Drucke 😍  Aber der Mk3s druckt besser , auch ohne Superpinda.
This post was modified 5 years temu by Reiner
Opublikowany : 17/01/2021 1:33 am
That is retraction to under extrusion issue.  Is this printer stock?
Opublikowany : 17/01/2021 2:21 pm
