Belt status X help
sTrAnGe--Tag
(@strange-tag)
Belt status X help
I have just finished assembling my I3 MKS and after the selftest i checked belt status: "X-202 Y286" so if i understand good it means  i have to loosen the belt, but compared to the Y if is already very loose, so if i do that it jumps up and down when doing the self test the pulley is firmly on the flat part of the motor and the bearing moves smooth.
Any suggestions ?
Posted : 22/02/2020 3:24 pm
vintagepc
(@vintagepc)
RE: Belt status X help
The numbers are backwards, lower numbers mean the belt is tighter. (Good on you for getting that right the first time - posting for others that might read this).
Also, they're a best-case guess at "belt tension". They are actually measuring the load on the motor, which is also affected by bearings and whatnot.
Basically, check your X axis for rough movement, binding, etc. if the belt is already loose. Many people overtighten the X carriage, so loosen those screws around the bearings a half turn or so and see if things improve.
Posted : 22/02/2020 5:46 pm
rmm200
(@rmm200)
Or do it my way. The Droop method.
Tighten your belts until there is no visible sag. Call it good.
Chasing those numbers can lead you to belts that are far too tight.
Posted : 22/02/2020 5:52 pm
sTrAnGe--Tag
(@strange-tag)
Posted by: @vintagepc
Thanx problem solved, tiny piece of plastic stuck between the bearing
Posted : 23/02/2020 2:47 pm
