Bed Levelling figures
I've done the Nylock bed levelling modification and used the Octoprint Plugin to so far get this result:
The overall bed figure is less than 0.02 but should I try and get the individual figures closer?
My Mac and printer aren't close together and so its time consuming (and a bit exhausting!) going back and forth to run the levelling and alter the screws. I did have it slightly better but then messed it up again trying to adjust one screw that bit more.
I haven't had any problems but was aware the front right of the bed was a bit higher than the rest and I'm planning on doing many instances of a very small object filling the build plate so thought it wise to get round to levelling before I start that printing.
Thanks
Napsal : 11/01/2021 1:21 pm
