Bed Leveling Issue
Hank
 Hank
(@hank-2)
Bed Leveling Issue
I am having trouble with my MK3S printer.  I was having an issue with the extruder not feeding filament during a print.  This occurred just after I updated to the latest firmware.  I did a reset and tried again but the issue remained.  Then things got worse.  I went through a XYZ calibration with no issues.  Then when I was doing the first layer cal, the extruder found the first two point but then crashed into the bed while approaching the 3rd point.  I went through the calibration again, got to the first layer cal and had the same issue of the extruder crashing into the build plate.  I check the PIDA probe by pushing the head across the X axis.  It seem to read correctly when a metal object was near.  Is there anything else that might cause the head to crash?
Postato : 12/10/2019 8:33 pm
rmm200
(@rmm200)
RE: Bed Leveling Issue
When you load new firmware, make sure you do a factory reset and clear.
Then start from Self Test.
Postato : 13/10/2019 12:14 am
