Bed level correction changes?
Cherry Dude
(@cherry-dude)
Hi there
So, having run all calibrations, adjusted Z and corrected bed levelling, I run a print that covers nearly the entire bed, and get the perfect consistent first layer. Now the issue is that I have done this several times now, because at some point it feels like the bed level correction values are discarded. I have not found the pattern to it yet, whether it is after the power is turned off, certain adjustments, or something completely different.
Am I perhaps missing something or is this a known issue? Again, everything runs perfectly, except this one issue - and to be honest it is a little annoying doing the corrections every other print (to exaggerate).
Publié : 09/06/2018 10:55 am
Nospoon
(@nospoon)
Re: Bed level correction changes?
Could it be PINDA temperature difference between the prints?
Publié : 20/06/2018 8:48 am
