bed calibration 9 points & 27 points
jeff.h2
(@jeff-h2)
I have a MK3 and MK3S printer.
The MK3S performs a 27 point calibration prior to each print
The MK3 performs a 9 point calibration prior to each print.
Why is this so?  How can I change the MK3 to perform the 27 point check?
Thanks
-Jeff
Opublikowany : 11/12/2019 4:57 pm
pingu
(@pingu)
RE: bed calibration 9 points & 27 points
if you have the firmware up to date, then you can change thois behavior in the printer setings. mesh bed 7x7 or 3x3
Opublikowany : 11/12/2019 4:58 pm
jeff.h2
(@jeff-h2)
That the spot....thanks.
-Jeff
Opublikowany : 11/12/2019 5:06 pm
