Bed adhesion and Z offset calibration concerns.
I have a Prusa MK3S+R and I am having a difficult time after getting a new print sheet (link below) and after washing it with IPA. On paper when I ran the Z offset first layer calibration (unsuccessfully several times) everything seemed fine until I attempted to print a few layers and I was greeted by this warped output. My Z offset is set to 0.950, in the Z offset calibration that was the best result that stuck to the sheet well and did not create a mess.
The reason I'm on this journey at all is because the first layer on the old sheet and with the old settings was streaky at the print bed and the layers were rough.
I am trying to figure out if it is a component that needs to be replaced or is there a calibration I am missing that I need to undergo to get this operational again.
Below are some pictures that might help.
