Bear Upgrade - Y Axis lenght error; lead screw
Hello,
i did some modification on my original Prusa MK3S. I added the
- Bear Mod
- linear rails of Marc https://www.prusaprinters.org/prints/3575-igus-y-axis-linear-rail-mod/comments and next to it
- I created a lead screw modification to it for Y-Axis. Self design - i would like to share but need to get it going first.
Now I receive in the self test the Y Axis lenght error what I don't understand. I modified the firmware already at several places of configuration_prusa such as
- E-Steps: at the moment it must be 400. (16 e-steps x 200 Steps)/8mm per round // basically it's same to the Z Axis: #define DEFAULT_AXIS_STEPS_PER_UNIT {100,400,3200/8,473} => I adjusted als E-Axis due to BunnyScience Extruder
- lenght correction of Y-Axis: #define Y_MAX_POS 213.9 (Pronterface actually measures: Measured axis length:213.820)
- Directions are inverted by switching cables
- Stallguard sensitivity I reduced (it sounded like the printer is about to explode when hitting at the ends): #define TMC2130_SG_THRS_Y 1
- Currents are adjusted: #define TMC2130_CURRENTS_H {16, 39, 35, 30}
Can anyone provide me some hints what i could do? Thanks in advance; below a picture of the mod.
Posted : 21/03/2020 12:48 pm
