Bad leveling z axis
MS
 MS
(@ms-4)
Bad leveling z axis
Hi all, I'm facing continuing failing during the Z axis leveling.
I updated the firmware of my MK3S and after it I was not able to start a print.
Every time that I was trying to start a print the printer goes through the z enforcement leveling and when reach the top the leveling fails.
I'm trying to go through the initial wizard but it continue to fail and I receive endstop error for Z axis.
Does anyone facing the same problem? Do you know how can I fix it?
Napsal : 01/02/2021 8:47 am
adesir
(@adesir)
MS
 MS
(@ms-4)
RE: Bad leveling z axis
@adesir
Tested. Unfortunately I still get the error. I checked with the tech support and also for them it it a PINDA failure.
I will wait a new part.
And in the meantime I will order also the SuperPINDA 😉
Napsal : 01/02/2021 3:44 pm
