avrdude-slic3r: prusa_init_external_flash(): MK3 printer emitted incorrect start code: `start\n`
[Risolto] avrdude-slic3r: prusa_init_external_flash(): MK3 printer emitted incorrect start code: `start\n`
Edu
 Edu
(@edu)
Hi:
I am trying to upgrade firmware of my prusa i3-mk3s from 3.9.3-RC to 3.9.3, and upgrade process fails with this error.
I attach log because wordpress does not accept my message pasting it: error_msg_upgrading
Printer boots with no error after process.
Please, can you help me?
Thanks.
Edu.
Postato : 25/01/2021 9:38 am
hli
 hli
(@hli)
RE: avrdude-slic3r: prusa_init_external_flash(): MK3 printer emitted incorrect start code: `start\n`
Looks like this issue: https://github.com/prusa3d/Prusa-Firmware/issues/2954
Maybe chime in there so Prusa knows from yet another case of this happening. For now, best is to go back to 3.9.2. (or try flashing again)
Postato : 25/01/2021 12:18 pm
Edu
 Edu
(@edu)
Thanks.
The issue is a little different than the issue you quote. But after reading it I have tryed to downgrade to previous version, 2.9.2, and it worked fine. Then I have ugraded to 2.9.3 and worked right too.
So the issue is fixed for me.
Thank you very much.
Edu.
Postato : 25/01/2021 1:12 pm
