Autoload Filament stopped working
gboast
(@gboast)
My autoload stopped working. It's been working great. All of a sudden. The gears are not moving when I I sent the filament . I have tried manually, and it works. What could be the issue? Could the sensor be dead?
Opublikowany : 22/06/2024 8:20 pm
RE: Autoload Filament stopped working
the sensor may need adjusting, or a washer like this
https://www.thingiverse.com/thing:4665750      or
https://www.thingiverse.com/thing:4006603
Opublikowany : 22/06/2024 8:38 pm
sique.scarface
(@sique-scarface)
I have a similar problem. My Prusa i3 MK3s stopped feeding in mid-print. It claimed the print being finished, but the last ~20 layers were missing despite filament being loaded. At first, I feared some clogging, so I cleaned the whole hotend, switched out the nozzle and the PVC tube, but when I am trying to feed filament, it does not detect it, and when I try to print, it doesn't feed any filament. I don't even manage to push the filament deep enough so it melts in the hotend and drops out. Then I tried to test the filament sensor, but it seems not to detect any sensor.
Opublikowany : 01/07/2024 2:33 pm
Check the connections on the filament sensor, you should have +5volts, ground  (0Volts) and the signal wire
if 5v and ground are present, the signal wire should show nearly 5 volts or nearly 0 volts, depending whether the filament sensor is at rest, or activated. and the filament sensor value in the LCD Sensors menu, should toggle between  0 and 1
it's possible that one of more of the filament sensor wires is faulty. they can fracture due to fatigue, from all of the flexing
Joan
Opublikowany : 01/07/2024 4:13 pm
sique.scarface
(@sique-scarface)
I'll check the voltage and come back with results. Thank you for the hint!
Opublikowany : 01/07/2024 8:09 pm
Good Luck
Joan
Opublikowany : 01/07/2024 8:22 pm
John
 John
(@john-6)
The filament trigger can get stuck as it is a very close fit. When facing the printer try backing off the screw which is top left of the filament loading block and next to the sensor connection.  For reference it passes through into the stepper motor. It may only need a quarter or less of one  turn to do its trick.
This was advice from prusa support when my sensor was unreliably detecting filament runout.
This post was modified 2 years temu 2 times by John
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Opublikowany : 01/07/2024 10:04 pm
sique.scarface
(@sique-scarface)
I checked the voltage between the pins labelled "+5V" and "GND", and I didn't measure anything. I checked also the reaction of the detector after dismounting it from the hotend, by moving a sheet of plastic between the sensor sender and receiver. For good measure, I also tested if the lever moved by putting filament into the hotend, which it did.
Then I measured if at least, I get +5V readouts from the plug of the cable, and I got a resounding 0.00 V.
Opublikowany : 02/07/2024 11:30 am
Looks like a cable fault.
Check voltages on motherboard
Joan
Opublikowany : 02/07/2024 1:13 pm
sique.scarface
(@sique-scarface)
I finally had the time to look into the filament sensor mystery more deeply. Root cause was a loose cable on the motherboard. I reseated the plug, fixed the cable with a tie, and now the sensor reports data again.
Opublikowany : 08/07/2024 9:48 am
