Autoload filament not working?
roach374
(@roach374)
I've had my i3 mk3 for a couple of months now, and I've been super happy with it. But today, after spending the last couple of days on a bunch of large prints, the filament sensor seems not to be working. It doesn't detect when I insert the filament, and won't autoload.
I opened the idler, and there isn't any blockage. I confirmed that the filament is going all the way into the PTFE tube when I insert it.
I've had my printer inside a LACK enclosure for the last couple of months. Is it possible that full-time printing for two or three days has overheated something? Maybe it's just tired, and needs a nap?
What else should I try?
Opublikowany : 20/01/2019 4:29 pm
roach374
(@roach374)
Re: Autoload filament not working?
Tried rebooting, auto-load filament is still not working. I wonder if it will detect when filament breaks or runs out?
Opublikowany : 21/01/2019 4:25 am
roach374
(@roach374)
Well, I Got in touch with tech support, and they walked me through step-by-step removing the sensor and checking it. Turns out the mirror was just dusty! I wiped it off, and the sensor works again. Problem solved!
THANKS, PRUSA TECH SUPPORT, YOU ROCK!
Opublikowany : 21/01/2019 6:26 am
