Any easy way to turn off nag message before I upgrade firmware?
jsw
 jsw
(@jsw)
This afternoon I clicked on the 'load updated parameters' (or something similar) message when I ran PrusaSlicer and now whenever I go to do a print it displays this 'Updated firmware available, please upgrade' message at the start of each print and does appear to delay the print start.
I don't want to flash new firmware until I finish with some important prints.
Is there any convenient way of turning off this nag message, at least temporarily?
Thanks.
Postato : 27/05/2020 7:30 am
Peter in Katy
(@peter-in-katy)
RE: Any easy way to turn off nag message before I upgrade firmware?
Look in the Start Gcode tab under Printer Settings.
Comment the first line, or the one that has a comment about current firmware.  Boom!  No nag message.
Questo post è stato modificato 6 years fa da Peter in Katy
Postato : 27/05/2020 2:02 pm
1 persone hanno apprezzato
jsw
 jsw
(@jsw)
Thanks.
I assume it's this line:
M115 U3.9.0 ; tell printer latest fw version
I won't be able to try it for a while because the current print has 6 more hours to run, but we'll see if it works after that.
Postato : 27/05/2020 2:19 pm
Lichtjaeger
(@lichtjaeger)
Or deactivate Firmware checks in the hardware settings of your printer.
Netpackrat
(@netpackrat)
Posted by: @lichtjaeger
I tried to do this, and for whatever reason the change didn't seem to make any difference.  I had to comment out the line in my start gcode as described above.  Printer in question has a modified (100mm taller) Z axis, which required compiling custom firmware.  Which I am not going to repeat every time Prusa comes out with an update unless there is some compelling reason to do so.
https://www.printables.com/@Netpackrat/models
Postato : 22/06/2022 4:08 am
Orbital
(@orbital)
Utenti
Same situation for me, turning off in firmware didn't turn off the messages, quite frustrating.
Postato : 16/10/2023 2:58 pm
