Angled cooling fan
tre4b
(@tre4b)
Angled cooling fan
Can anyone tell me why this changed from vertical to angled on the latest version?
I wanted to add something and the angle is in the way. I'm trying to find out what the problem would be in going back to the original vertical setup.
Publié : 19/01/2019 11:51 am
Re: Angled cooling fan
Hi Trevor,
the 45 degree angled fan is reputed to provide better cooling air flow than the 90 degree angled fan.
I use 90 degree on my mk3 with mmu and don't seem to have cooling difficulties, however I don't use the standard part cooling fan duct... and I am not sure which alternative it is
Publié : 19/01/2019 1:28 pm
robert.t17
(@robert-t17)
I printed some parts from clear filament with the original cooling fan. Wasn't happy with the results. Later I installed the Mosquito hot end which has a different cooling fan implementation. On a whim I reprinted the parts and they came out fine. I mentioned this to a friend of mine. He ordered the same filament and printed the same parts with the new Prusa fan parts with the same results. He than installed a Mosquito hot end and printed with good results. His results verified mine. Seems cooling is a more complicated process than one would think.
Publié : 19/01/2019 2:07 pm
RH_Dreambox
(@rh_dreambox)
Yes the air nozzle is a complicated but important component 😯
https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64/playing-with-the-air-nozzle-design-t25642.html
Publié : 19/01/2019 2:27 pm
