After update to firmware 3.9.3 printer stops after choosing print from SD
[Rozwiązany] After update to firmware 3.9.3 printer stops after choosing print from SD
Georg Müller
(@georg-muller)
I did the update without problems with Slicer Version 2.2. When I tried printing I got the stop after klicking to the first model. the I updated the slicer to 2.3 and updated updated the firmware again. The problem is not solved yet. Can anybody help me please?
Opublikowany : 24/02/2021 2:07 pm
Georg Müller
(@georg-muller)
RE: After update to firmware 3.9.3 printer stops after choosing print from SD
This video shows the problem
Opublikowany : 24/02/2021 2:27 pm
Georg Müller
(@georg-muller)
I did the update again and then tried to change the language to german on the printer - this caused also a shut down.
The installation of the update had no errors. What can be the root cause. Thanks in advance.
Opublikowany : 24/02/2021 2:57 pm
Georg Müller
(@georg-muller)
Also a factory reset did not help. I also had to wait for about 15 seconds till the factory reset display appeared.  I now have strange letters on the display when I want to change the  language. The printer starts up regular but when I want to calibrate I have again strange letters on the display.
Opublikowany : 24/02/2021 3:58 pm
Georg Müller
(@georg-muller)
Now I installed version 3.9.2 and everything works. If I have time I will try 3.9.3 again.
Opublikowany : 24/02/2021 5:28 pm
hli
 hli
(@hli)
Probably another case of https://github.com/prusa3d/Prusa-Firmware/issues/2954 . For now going back to 3.9.2 seems to be the only solution.
Opublikowany : 24/02/2021 10:10 pm
1 ludzie polubili
Georg Müller
(@georg-muller)
Yes I had the same screens. My Prusa was delivered November 2020.
Thank you very much for the answer.
Opublikowany : 25/02/2021 10:21 am
