After MMU2S deinstall XYZ Calibration fails
FXSR
 FXSR
(@fxsr)
Hey,
i hope that you can give me some advice. I bought an i3MK3S with an MMU2S already installed.
Since I needed some adapters printed and the MMU2S wasn´t doing as well and i needed them quickly,
I decided to deinstall the unit. (On my other i3MK3S everything is well, having no problems at all.)
I was the Lack Enclosure for the one that is now making big problems, since it doing the XYZ Calibration and finishing it, suddenly stops after
calibration point 4 and giving following advice:
XYZ Calibration failed. Please consult the manual.
I ll post you the script of octoprint:
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x00
Recv: Wizard end state: 3
Recv: echo:busy: paused for user
Recv: ok
Send: N1 M115*39
Recv: echo:endstops hit:  Z:182.66
Recv: FIRMWARE_NAME:Prusa-Firmware 3.11.0 based on Marlin FIRMWARE_URL: https://github.com/prusa3d/Prusa-Firmware  PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:AUTOREPORT_FANS:1
Recv: Cap:AUTOREPORT_POSITION:1
Recv: Cap:EXTENDED_M20:1
Recv: ok
Send: M21
Recv: echo:SD init fail
Recv: ok
Send: M113 S2
Recv: ok
Send: M155 S2
Recv: ok
Recv: echo:enqueing "M45"
Recv: tmc2130_home_enter(axes_mask=0x01)
Recv:   0 step=61 mscnt= 990
Recv: tmc2130_goto_step 0 61 2 1000
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x01
Recv: tmc2130_home_enter(axes_mask=0x02)
Recv:   0 step= 2 mscnt=  35
Recv: tmc2130_goto_step 1 1 2 1000
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x02
Recv: tmc2130_home_enter(axes_mask=0x04)
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x04
Recv: Iteration: 1
Recv: xyzcal_meassure_enter
Recv: xyzcal_searchZ x=1206 y=603 z=1999
Recv: xyzcal_spiral8 cx=1206 cy=603 z0=1999 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1999 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1899 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1799 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1699 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=1206 cy=603 z0=1599 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1599 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1499 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1399 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1299 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=1206 cy=603 z0=1199 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1199 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1099 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=999 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=1206 cy=603 z0=899 dz=100 radius=-900 ad=2
Recv:  ON-SIGNAL at x=633 y=-10 z=892 ad=2216
Recv: Scan countdown: 64
Recv: 63
Recv: 62
Recv: 61
Recv: 60
Recv: 59
Recv: 58
Recv: 57
Recv: 56
Recv: 55
Recv: 54
Recv: 53
Recv: 52
Recv: 51
Recv: 50
Recv: 49
Recv: 48
Recv: 47
Recv: 46
Recv: 45
Recv: 44
Recv: 43
Recv: 42
Recv: 41
Recv: 40
Recv: 39
Recv: 38
Recv: 37
Recv: 36
Recv: 35
Recv: 34
Recv: 33
Recv: 32
Recv: 31
Recv: 30
Recv: 29
Recv: 28
Recv: 27
Recv: 26
Recv: 25
Recv: 24
Recv: 23
Recv: 22
Recv: 21
Recv: 20
Recv: 19
Recv: 18
Recv: 17
Recv: 16
Recv: 15
Recv: 14
Recv: 13
Recv: 12
Recv: 11
Recv: 10
Recv: 9
Recv: 8
Recv: 7
Recv: 6
Recv: 5
Recv: 4
Recv: 3
Recv: 2
Recv: 1
Recv:
Recv: 01020a0800050a0a01090b060416252a2e251608090c0a070a0d09070b0a0707
Recv: 0000080300000a090209090000122e3c3c270d00000b0500070a010009090001
Recv: 0000070400030c110b0c07000000233535230000000904000709000007060000
Recv: 00010a06000b2025242008000000061e1d080000000c0700070a010009080002
Recv: 01020c0a0716314240310800000000000000000007110700080b040009090205
Recv: 00000b0a08183e524e3406000000000000000000120e0000020a00010b090003
Recv: 0000080100153c4e492601000000000000000000030000000003000006060000
Recv: 0000040000002134321808000000000000000000000000000000000006070000
Recv: 000002000000000c15100b060000000000000000000000000000000007070000
Recv: 0100020000000000000b0b0700000000000000000000000000000001090a0003
Recv: 000100000000000000080200000000000000000000000000000000000b090003
Recv: 00000000000000000000000000030d1713030000000000000000000009080002
Recv: 0000000000000000000000000f2a3b403e342100000000000000000005060000
Recv: 0000000000000000000000002c444c4d4b4a3f25000000000000000006060000
Recv: 01010400000000000000000f3f50524b4b4d4f4016000000000000000a090004
Recv: 00010900000000000000001644504d4747494f4a25000000000000000b080003
Recv: 00010a010000000000000014424e4a4643495049270000000000000008070002
Recv: 00010a0200000000000000053c4c4b47484b4e44200000000000000008050002
Recv: 00010a02000000000000000026444b4b4b4a4531000000000000000007070000
Recv: 0001090500000000000000000c3241484840320b000000000000000008030000
Recv: 00000a0400000000000000000005192525190000000000000000000006060000
Recv: 00010a0200000000000000000000000000000000000000000000000006040001
Recv: 0001090500000000000000000000000000000000000000000000000008060001
Recv: 00010a02000002000000110d0000000000000000000000000000000006050000
Recv: 0001090100000801001c39391600000000000000000000000000000006050001
Recv: 0000090100000a000624454b330000000000000b000000000000000006050000
Recv: 0000090400010a0609223e4436180000000927332c1400000004000007040000
Recv: 01000a0400010a010015272d2518010000182e34301e04000007000006040001
Recv: 00010a0400000a01000c16151514080001152021211604000108000007070001
Recv: 00000a0700040b0300080b09080a0900010c0c0a0b0b01000507000008070002
Recv: 00010a0500010a0100060a0000090700000a0700050a01000107000007020000
Recv: 0200090600030a0100070a000009090000090500010900000609000007060001
Recv:
Recv: Pattern center [15.500000 15.500000], match 84.848480%
Recv: Pattern center [15.500000 15.500000], match 96.969696%
Recv:  [15.535068, 15.644967][4.467708] final circle
Recv:  [12.082443 6.122779] mm pattern center
Recv: xyzcal_meassure_leave
Recv: xyzcal_searchZ x=22117 y=603 z=2019
Recv: xyzcal_spiral8 cx=22117 cy=603 z0=2019 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=2019 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1919 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1819 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1719 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=22117 cy=603 z0=1619 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1619 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1519 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1419 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1319 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=22117 cy=603 z0=1219 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1219 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1119 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1019 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=22117 cy=603 z0=919 dz=100 radius=-900 ad=2
Recv:  ON-SIGNAL at x=22261 y=706 z=839 ad=2757
Recv: 63
Recv: 62
Recv: 61
Recv: 60
Recv: 59
Recv: 58
Recv: 57
Recv: 56
Recv: 55
Recv: 54
Recv: 53
Recv: 52
Recv: 51
Recv: 50
Recv: 49
Recv: 48
Recv: 47
Recv: 46
Recv: 45
Recv: 44
Recv: 43
Recv: 42
Recv: 41
Recv: 40
Recv: 39
Recv: 38
Recv: 37
Recv: 36
Recv: 35
Recv: 34
Recv: 33
Recv: 32
Recv: 31
Recv: 30
Recv: 29
Recv: 28
Recv: 27
Recv: 26
Recv: 25
Recv: 24
Recv: 23
Recv: 22
Recv: 21
Recv: 20
Recv: 19
Recv: 18
Recv: 17
Recv: 16
Recv: 15
Recv: 14
Recv: 13
Recv: 12
Recv: 11
Recv: 10
Recv: 9
Recv: 8
Recv: 7
Recv: 6
Recv: 5
Recv: 4
Recv: 3
Recv: 2
Recv: 1
Recv:
Recv: 000e1e1e202d21212d2f26262e302c2d2f1e0204140300000000000000000000
Recv: 000e1f1d202c21212c2e27262e2f2b2e302d2036545125000000000000000000
Recv: 00111f1f262d22202e2f2c2c32302a2e3a32305270785e170000000000000000
Recv: 0011201f202c24212f39353239332c2f3a3b3d5a777d6d3e0000000000000000
Recv: 00121f1f262c20203845484747392c30464d4e5c6c6e634b0b00000000000000
Recv: 00102020262c2020394e5d5c4f3b262e4b5d64695e574a3a0f00000000000000
Recv: 000f1e1e212319122c495e5e4a220f1d3c5d625e4a2e2c2d0b00000000000000
Recv: 000f1e1e20200400001f363c1f00000012313e311400071e0900000000000000
Recv: 000e1d1f201700000000000000000000000000000000000f0400000000000000
Recv: 00131f1e1f110000000000000000000000000000000000010000000000000000
Recv: 001b211e200f0000000000000000000000000000000000000100000000000000
Recv: 0f20211e1e0e0000000000000008000000000000000000000100000000000000
Recv: 1720211d1f1000000000002b4a554f3d13000000000000000100000000000000
Recv: 1e29241e2015000000023d5e6f76746d551f0000000000000100000000000000
Recv: 1e2b241f201e0200023c6b767b7d7d7c724c0500000000000100000000000000
Recv: 222c281e282b13112e5f767e79787b7f7b6a2c00000000000100000000000000
Recv: 212b291f2b2d2020406b7e7d7671747c7f6e3a00000000000100000000000000
Recv: 1f2a241f292c1e1e3b6a7b7d7772747a7d6d3000000000000000000000000000
Recv: 242c2a1f2a2a11021e56707b7b7a7c7e79612000000000000000000000000000
Recv: 222d2a1f261f0000002b5d71787b7c796d3d0000000000000000000000000000
Recv: 252c2b1f2715000000002b55696e6d60460b0000000000000100000000000000
Recv: 262d291f2010000000000012363e3d2900000000000000000100000000000000
Recv: 242d2a1f20100000000000000000000000000000000000080300000000000000
Recv: 232d291f201000000000000000000000000000000000001c0a00000000000000
Recv: 212c2b20241500000000000000000000000000000000172e0c00000000000000
Recv: 242c2a20291f000000000001020403010000000000213c3a0300000000000000
Recv: 242c2b212b2a11051c2e302d1f2025201f120f1421313b210000000000000000
Recv: 282d2a222b2d21203440371f1b1e29200f0000011b2c2a030000000000000000
Recv: 292e2a1f2c2f2b2b393b1f070f262e2708000000122c2c030000000000000000
Recv: 292d2b202d302c2c34311d0e1f4556481f000000334f4c2b0000000000000000
Recv: 292e2c282e332d2a342f1f1e40666e69491e0f2a576e6e4e0500000000000000
Recv: 2a2e2c272e372c2b37372b2f4c686f6c5a372b4265706f5c1600000000000000
Recv:
Recv: Pattern center [14.500000 16.500000], match 75.757576%
Recv: Pattern center [13.500000 16.500000], match 90.909088%
Recv:  [13.195663, 16.360512][5.063694] final circle
Recv:  [219.695240 6.580728] mm pattern center
Recv: xyzcal_searchZ x=22117 y=19895 z=1966
Recv: xyzcal_spiral8 cx=22117 cy=19895 z0=1966 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1966 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1866 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1766 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1666 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=22117 cy=19895 z0=1566 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1566 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1466 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1366 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1266 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=22117 cy=19895 z0=1166 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1166 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1066 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=966 dz=100 radius=900 ad=3
Recv:  ON-SIGNAL at x=22130 y=19891 z=967 ad=1460
Recv: 63
Recv: 62
Recv: 61
Recv: 60
Recv: 59
Recv: 58
Recv: 57
Recv: 56
Recv: 55
Recv: 54
Recv: 53
Recv: 52
Recv: 51
Recv: 50
Recv: 49
Recv: 48
Recv: 47
Recv: 46
Recv: 45
Recv: 44
Recv: 43
Recv: 42
Recv: 41
Recv: 40
Recv: 39
Recv: 38
Recv: 37
Recv: 36
Recv: 35
Recv: 34
Recv: 33
Recv: 32
Recv: 31
Recv: 30
Recv: 29
Recv: 28
Recv: 27
Recv: 26
Recv: 25
Recv: 24
Recv: 23
Recv: 22
Recv: 21
Recv: 20
Recv: 19
Recv: 18
Recv: 17
Recv: 16
Recv: 15
Recv: 14
Recv: 13
Recv: 12
Recv: 11
Recv: 10
Recv: 9
Recv: 8
Recv: 7
Recv: 6
Recv: 5
Recv: 4
Recv: 3
Recv: 2
Recv: 1
Recv:
Recv: 000000000000000000000000112a302c11000000000000000000000000000000
Recv: 00000000000000000000000001202d2102000000040606000000000000000000
Recv: 0000000000000000000000000001100000000000091d1f110000000000000000
Recv: 0000000000000000000000000000000000000000102d34200000000000000000
Recv: 0000000000000000000200000000000000000000012e412d0000000000000000
Recv: 0000000000000000000000000000000000000000001e332d0000000000000000
Recv: 0000000000000000000000000000000000000000000010040000000000000000
Recv: 0000000000000000000000000000000000000000000000000000000000000000
Recv: 000000000000000000000000020c0d0200000000000000000000000000000000
Recv: 00000000000000000000001d2d32332e20050000000000000000000000000000
Recv: 0000000000000000000023343d3c413e351c0000000000000000000000000000
Recv: 0000000000000000001e353e3c3a3c403f2a0000000000000000000000000000
Recv: 000000000000000003293d3d3433353e3f2d0000000000000000000000000000
Recv: 0000000000000000032b3d3c3231323f3f2c0000000000000000000000000000
Recv: 0000000000000000001e353c3837383d3c210000000000000000000000000000
Recv: 0000000000000000000024343b3d3c3b31120000000000000000000000000000
Recv: 0000000000000000000003212e33322b1d000000000000000000000000000000
Recv: 0000000000000000000000000512090100000000000000000000000000000000
Recv: 000000000000000000000000000000000000000a000000000000000000000000
Recv: 00000000000000000000000000000000000026311d0000000000000000000000
Recv: 150b0000000000000005040000000000001b3d3e240300000000000000000000
Recv: 2c1d000000000000112b2e1500000000001f3637200200000000000000000000
Recv: 2f1e000000000000102d332a1200000002181f20110000000000000000000000
Recv: 1d11000000000000091e21201300000000060608040000000000000000000000
Recv: 0000000000000000000306070600000000000000000000000000000000000000
Recv:
Recv: Pattern center [12.500000 14.500000], match 90.151512%
Recv: Pattern center [13.500000 14.500000], match 91.666664%
Recv:  [13.236731, 14.455117][4.116258] final circle
Recv:  [219.721500 198.281270] mm pattern center
Recv: xyzcal_searchZ x=1206 y=19895 z=2094
Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=2094 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=2094 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1994 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1894 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1794 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=1694 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1694 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1594 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1494 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1394 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=1294 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1294 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1194 dz=100 radius=-900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1094 dz=100 radius=900 ad=3
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=994 dz=100 radius=-900 ad=2
Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=894 dz=100 radius=900 ad=0
Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=894 dz=100 radius=900 ad=0
Recv:  ON-SIGNAL at x=1225 y=19987 z=883 ad=100
Recv: 63
Recv: 62
Recv: 61
Recv: 60
Recv: 59
Recv: 58
Recv: 57
Recv: 56
Recv: 55
Recv: 54
Recv: 53
Recv: 52
Recv: 51
Recv: 50
Recv: 49
Recv: 48
Recv: 47
Recv: 46
Recv: 45
Recv: 44
Recv: 43
Recv: 42
Recv: 41
Recv: 40
Recv: 39
Recv: 38
Recv: 37
Recv: 36
Recv: 35
Recv: 34
Recv: 33
Recv: 32
Recv: 31
Recv: 30
Recv: 29
Recv: 28
Recv: 27
Recv: 26
Recv: 25
Recv: 24
Recv: 23
Recv: 22
Recv: 21
Recv: 20
Recv: 19
Recv: 18
Recv: 17
Recv: 16
Recv: 15
Recv: 14
Recv: 13
Recv: 12
Recv: 11
Recv: 10
Recv: 9
Recv: 8
Recv: 7
Recv: 6
Recv: 5
Recv: 4
Recv: 3
Recv: 2
Recv: 1
Recv:
Recv: 0000040100000100000102000001010000010000000000000000000000000000
Recv: 0000030100000300000002000003020000010000000000000000000000000000
Recv: 000003000000030000020b040306020000030200000200000000000000000000
Recv: 1a00030000000200000d161c1611020000050f0f100e00000000000000000000
Recv: 1b0003000000020000142b2f2c19000000061b21211301000000000000000000
Recv: 1a0001000000010001203c463311000000001d32352103000000000000000000
Recv: 1a00010000000200001e3d452700000000001130331f00000000000000000000
Recv: 1a00010000000000000d2b2904000000000000141c0200000000000000000000
Recv: 1a00010100000000000000000000000000000000000000000000000000000000
Recv: 1900010000000000000000000000000000000000000000000000000000000000
Recv: 1a000100000000000000000000000d1316110200000000000000000000000000
Recv: 1900000000000000000000000629383b3c382702000000000000000000000000
Recv: 0000000000000000000000002340474546473d22000000000000000000000000
Recv: 0000000000000000000000023647454141454637080000000000000000000000
Recv: 1900000000000000000000123c46413b3c3f463b160000000000000000000000
Recv: 1900000000000000000000113b45413c3a40443d150000000000000000000000
Recv: 0000000000000000000000053244423f3f424331070000000000000000000000
Recv: 000000000000000000000000203b434343443a1d000000000000000000000000
Recv: 0000000000000000000000000221343a39301d00000000000000000000000000
Recv: 0000000000000000000000000000081212060000000000000000000000000000
Recv: 0000000000001723150000000000000000000000000000000000000000000000
Recv: 00000000000f3241300f00000000000000000000010000000000000000000000
Recv: 0000000000103244391700000000000000000000000000000000000000000000
Recv: 00000000000726312b1400000000000703000000000000000000000000000000
Recv: 0000000000001016120d0000000015251f060000000000000000000000000000
Recv: 0000000000000102000000000005212d2c140000000000000000000000000000
Recv: 00000000000000000000000000081b1f1d100000000000000000000000000000
Recv: 0000000000000000000000000001070405030000000000000000000000000000
Recv:
Recv: Pattern center [15.500000 14.500000], match 87.121208%
Recv: Pattern center [15.500000 14.500000], match 94.696968%
Recv:  [15.484080, 14.423905][4.243558] final circle
Recv:  [12.049811 198.261310] mm pattern center
Recv: All 4 calibration points found.
Recv: Measured skews: 0.063761 -0.002032
Would appreciate your help a lot.
Thank you
Publié : 12/04/2022 5:53 pm
