After MMU2S deinstall XYZ Calibration fails
Hey,
i hope that you can give me some advice. I bought an i3MK3S with an MMU2S already installed.
Since I needed some adapters printed and the MMU2S wasn´t doing as well and i needed them quickly,
I decided to deinstall the unit. (On my other i3MK3S everything is well, having no problems at all.)
I was the Lack Enclosure for the one that is now making big problems, since it doing the XYZ Calibration and finishing it, suddenly stops after
calibration point 4 and giving following advice:
XYZ Calibration failed. Please consult the manual.
I ll post you the script of octoprint:
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x00 Recv: Wizard end state: 3 Recv: echo:busy: paused for user Recv: ok Send: N1 M115*39 Recv: echo:endstops hit: Z:182.66 Recv: FIRMWARE_NAME:Prusa-Firmware 3.11.0 based on Marlin FIRMWARE_URL: https://github.com/prusa3d/Prusa-Firmware PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 Recv: Cap:AUTOREPORT_TEMP:1 Recv: Cap:AUTOREPORT_FANS:1 Recv: Cap:AUTOREPORT_POSITION:1 Recv: Cap:EXTENDED_M20:1 Recv: ok Send: M21 Recv: echo:SD init fail Recv: ok Send: M113 S2 Recv: ok [...] Send: M155 S2 Recv: ok [...] Recv: echo:enqueing "M45" Recv: tmc2130_home_enter(axes_mask=0x01) [...] Recv: 0 step=61 mscnt= 990 Recv: tmc2130_goto_step 0 61 2 1000 Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x01 Recv: tmc2130_home_enter(axes_mask=0x02) [...] Recv: 0 step= 2 mscnt= 35 Recv: tmc2130_goto_step 1 1 2 1000 Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x02 [...] Recv: tmc2130_home_enter(axes_mask=0x04) [...] Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x04 [...] Recv: echo:busy: paused for user [...] Recv: echo:busy: paused for user [...] Recv: echo:busy: paused for user [...] Recv: tmc2130_home_enter(axes_mask=0x04) [...] Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x04 Recv: Iteration: 1 [...] Recv: xyzcal_meassure_enter Recv: xyzcal_searchZ x=1206 y=603 z=1999 Recv: xyzcal_spiral8 cx=1206 cy=603 z0=1999 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1999 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1899 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1799 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1699 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=1206 cy=603 z0=1599 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1599 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1499 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1399 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1299 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=1206 cy=603 z0=1199 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1199 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=1099 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=999 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=1206 cy=603 z0=899 dz=100 radius=-900 ad=2 Recv: ON-SIGNAL at x=633 y=-10 z=892 ad=2216 Recv: Scan countdown: 64 Recv: 63 Recv: 62 Recv: 61 Recv: 60 Recv: 59 Recv: 58 Recv: 57 Recv: 56 Recv: 55 Recv: 54 Recv: 53 Recv: 52 Recv: 51 Recv: 50 Recv: 49 Recv: 48 Recv: 47 Recv: 46 Recv: 45 Recv: 44 Recv: 43 Recv: 42 Recv: 41 Recv: 40 Recv: 39 Recv: 38 Recv: 37 Recv: 36 Recv: 35 Recv: 34 Recv: 33 Recv: 32 Recv: 31 Recv: 30 Recv: 29 Recv: 28 Recv: 27 Recv: 26 Recv: 25 Recv: 24 Recv: 23 Recv: 22 Recv: 21 Recv: 20 Recv: 19 Recv: 18 Recv: 17 Recv: 16 Recv: 15 Recv: 14 Recv: 13 Recv: 12 Recv: 11 Recv: 10 Recv: 9 Recv: 8 Recv: 7 Recv: 6 Recv: 5 Recv: 4 Recv: 3 Recv: 2 Recv: 1 Recv: Recv: 01020a0800050a0a01090b060416252a2e251608090c0a070a0d09070b0a0707 Recv: 0000080300000a090209090000122e3c3c270d00000b0500070a010009090001 Recv: 0000070400030c110b0c07000000233535230000000904000709000007060000 Recv: 00010a06000b2025242008000000061e1d080000000c0700070a010009080002 Recv: 01020c0a0716314240310800000000000000000007110700080b040009090205 Recv: 00000b0a08183e524e3406000000000000000000120e0000020a00010b090003 Recv: 0000080100153c4e492601000000000000000000030000000003000006060000 Recv: 0000040000002134321808000000000000000000000000000000000006070000 Recv: 000002000000000c15100b060000000000000000000000000000000007070000 Recv: 0100020000000000000b0b0700000000000000000000000000000001090a0003 Recv: 000100000000000000080200000000000000000000000000000000000b090003 Recv: 00000000000000000000000000030d1713030000000000000000000009080002 Recv: 0000000000000000000000000f2a3b403e342100000000000000000005060000 Recv: 0000000000000000000000002c444c4d4b4a3f25000000000000000006060000 Recv: 01010400000000000000000f3f50524b4b4d4f4016000000000000000a090004 Recv: 00010900000000000000001644504d4747494f4a25000000000000000b080003 Recv: 00010a010000000000000014424e4a4643495049270000000000000008070002 Recv: 00010a0200000000000000053c4c4b47484b4e44200000000000000008050002 Recv: 00010a02000000000000000026444b4b4b4a4531000000000000000007070000 Recv: 0001090500000000000000000c3241484840320b000000000000000008030000 Recv: 00000a0400000000000000000005192525190000000000000000000006060000 Recv: 00010a0200000000000000000000000000000000000000000000000006040001 Recv: 0001090500000000000000000000000000000000000000000000000008060001 Recv: 00010a02000002000000110d0000000000000000000000000000000006050000 Recv: 0001090100000801001c39391600000000000000000000000000000006050001 Recv: 0000090100000a000624454b330000000000000b000000000000000006050000 Recv: 0000090400010a0609223e4436180000000927332c1400000004000007040000 Recv: 01000a0400010a010015272d2518010000182e34301e04000007000006040001 Recv: 00010a0400000a01000c16151514080001152021211604000108000007070001 Recv: 00000a0700040b0300080b09080a0900010c0c0a0b0b01000507000008070002 Recv: 00010a0500010a0100060a0000090700000a0700050a01000107000007020000 Recv: 0200090600030a0100070a000009090000090500010900000609000007060001 Recv: Recv: Pattern center [15.500000 15.500000], match 84.848480% Recv: Pattern center [15.500000 15.500000], match 96.969696% Recv: [15.535068, 15.644967][4.467708] final circle Recv: [12.082443 6.122779] mm pattern center Recv: xyzcal_meassure_leave [...] Recv: xyzcal_meassure_enter Recv: xyzcal_searchZ x=22117 y=603 z=2019 Recv: xyzcal_spiral8 cx=22117 cy=603 z0=2019 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=2019 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1919 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1819 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1719 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=22117 cy=603 z0=1619 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1619 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1519 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1419 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1319 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=22117 cy=603 z0=1219 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1219 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1119 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=1019 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=22117 cy=603 z0=919 dz=100 radius=-900 ad=2 Recv: ON-SIGNAL at x=22261 y=706 z=839 ad=2757 Recv: Scan countdown: 64 Recv: 63 Recv: 62 Recv: 61 Recv: 60 Recv: 59 Recv: 58 Recv: 57 Recv: 56 Recv: 55 Recv: 54 Recv: 53 Recv: 52 Recv: 51 Recv: 50 Recv: 49 Recv: 48 Recv: 47 Recv: 46 Recv: 45 Recv: 44 Recv: 43 Recv: 42 Recv: 41 Recv: 40 Recv: 39 Recv: 38 Recv: 37 Recv: 36 Recv: 35 Recv: 34 Recv: 33 Recv: 32 Recv: 31 Recv: 30 Recv: 29 Recv: 28 Recv: 27 Recv: 26 Recv: 25 Recv: 24 Recv: 23 Recv: 22 Recv: 21 Recv: 20 Recv: 19 Recv: 18 Recv: 17 Recv: 16 Recv: 15 Recv: 14 Recv: 13 Recv: 12 Recv: 11 Recv: 10 Recv: 9 Recv: 8 Recv: 7 Recv: 6 Recv: 5 Recv: 4 Recv: 3 Recv: 2 Recv: 1 Recv: Recv: 000e1e1e202d21212d2f26262e302c2d2f1e0204140300000000000000000000 Recv: 000e1f1d202c21212c2e27262e2f2b2e302d2036545125000000000000000000 Recv: 00111f1f262d22202e2f2c2c32302a2e3a32305270785e170000000000000000 Recv: 0011201f202c24212f39353239332c2f3a3b3d5a777d6d3e0000000000000000 Recv: 00121f1f262c20203845484747392c30464d4e5c6c6e634b0b00000000000000 Recv: 00102020262c2020394e5d5c4f3b262e4b5d64695e574a3a0f00000000000000 Recv: 000f1e1e212319122c495e5e4a220f1d3c5d625e4a2e2c2d0b00000000000000 Recv: 000f1e1e20200400001f363c1f00000012313e311400071e0900000000000000 Recv: 000e1d1f201700000000000000000000000000000000000f0400000000000000 Recv: 00131f1e1f110000000000000000000000000000000000010000000000000000 Recv: 001b211e200f0000000000000000000000000000000000000100000000000000 Recv: 0f20211e1e0e0000000000000008000000000000000000000100000000000000 Recv: 1720211d1f1000000000002b4a554f3d13000000000000000100000000000000 Recv: 1e29241e2015000000023d5e6f76746d551f0000000000000100000000000000 Recv: 1e2b241f201e0200023c6b767b7d7d7c724c0500000000000100000000000000 Recv: 222c281e282b13112e5f767e79787b7f7b6a2c00000000000100000000000000 Recv: 212b291f2b2d2020406b7e7d7671747c7f6e3a00000000000100000000000000 Recv: 1f2a241f292c1e1e3b6a7b7d7772747a7d6d3000000000000000000000000000 Recv: 242c2a1f2a2a11021e56707b7b7a7c7e79612000000000000000000000000000 Recv: 222d2a1f261f0000002b5d71787b7c796d3d0000000000000000000000000000 Recv: 252c2b1f2715000000002b55696e6d60460b0000000000000100000000000000 Recv: 262d291f2010000000000012363e3d2900000000000000000100000000000000 Recv: 242d2a1f20100000000000000000000000000000000000080300000000000000 Recv: 232d291f201000000000000000000000000000000000001c0a00000000000000 Recv: 212c2b20241500000000000000000000000000000000172e0c00000000000000 Recv: 242c2a20291f000000000001020403010000000000213c3a0300000000000000 Recv: 242c2b212b2a11051c2e302d1f2025201f120f1421313b210000000000000000 Recv: 282d2a222b2d21203440371f1b1e29200f0000011b2c2a030000000000000000 Recv: 292e2a1f2c2f2b2b393b1f070f262e2708000000122c2c030000000000000000 Recv: 292d2b202d302c2c34311d0e1f4556481f000000334f4c2b0000000000000000 Recv: 292e2c282e332d2a342f1f1e40666e69491e0f2a576e6e4e0500000000000000 Recv: 2a2e2c272e372c2b37372b2f4c686f6c5a372b4265706f5c1600000000000000 Recv: Recv: Pattern center [14.500000 16.500000], match 75.757576% Recv: Pattern center [13.500000 16.500000], match 90.909088% Recv: [13.195663, 16.360512][5.063694] final circle Recv: [219.695240 6.580728] mm pattern center Recv: xyzcal_meassure_leave [...] Recv: xyzcal_meassure_enter Recv: xyzcal_searchZ x=22117 y=19895 z=1966 Recv: xyzcal_spiral8 cx=22117 cy=19895 z0=1966 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1966 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1866 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1766 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1666 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=22117 cy=19895 z0=1566 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1566 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1466 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1366 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1266 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=22117 cy=19895 z0=1166 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1166 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=1066 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=22117 cy=19895 z0=966 dz=100 radius=900 ad=3 Recv: ON-SIGNAL at x=22130 y=19891 z=967 ad=1460 Recv: Scan countdown: 64 Recv: 63 Recv: 62 Recv: 61 Recv: 60 Recv: 59 Recv: 58 Recv: 57 Recv: 56 Recv: 55 Recv: 54 Recv: 53 Recv: 52 Recv: 51 Recv: 50 Recv: 49 Recv: 48 Recv: 47 Recv: 46 Recv: 45 Recv: 44 Recv: 43 Recv: 42 Recv: 41 Recv: 40 Recv: 39 Recv: 38 Recv: 37 Recv: 36 Recv: 35 Recv: 34 Recv: 33 Recv: 32 Recv: 31 Recv: 30 Recv: 29 Recv: 28 Recv: 27 Recv: 26 Recv: 25 Recv: 24 Recv: 23 Recv: 22 Recv: 21 Recv: 20 Recv: 19 Recv: 18 Recv: 17 Recv: 16 Recv: 15 Recv: 14 Recv: 13 Recv: 12 Recv: 11 Recv: 10 Recv: 9 Recv: 8 Recv: 7 Recv: 6 Recv: 5 Recv: 4 Recv: 3 Recv: 2 Recv: 1 Recv: Recv: 000000000000000000000000112a302c11000000000000000000000000000000 Recv: 00000000000000000000000001202d2102000000040606000000000000000000 Recv: 0000000000000000000000000001100000000000091d1f110000000000000000 Recv: 0000000000000000000000000000000000000000102d34200000000000000000 Recv: 0000000000000000000200000000000000000000012e412d0000000000000000 Recv: 0000000000000000000000000000000000000000001e332d0000000000000000 Recv: 0000000000000000000000000000000000000000000010040000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 000000000000000000000000020c0d0200000000000000000000000000000000 Recv: 00000000000000000000001d2d32332e20050000000000000000000000000000 Recv: 0000000000000000000023343d3c413e351c0000000000000000000000000000 Recv: 0000000000000000001e353e3c3a3c403f2a0000000000000000000000000000 Recv: 000000000000000003293d3d3433353e3f2d0000000000000000000000000000 Recv: 0000000000000000032b3d3c3231323f3f2c0000000000000000000000000000 Recv: 0000000000000000001e353c3837383d3c210000000000000000000000000000 Recv: 0000000000000000000024343b3d3c3b31120000000000000000000000000000 Recv: 0000000000000000000003212e33322b1d000000000000000000000000000000 Recv: 0000000000000000000000000512090100000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 000000000000000000000000000000000000000a000000000000000000000000 Recv: 00000000000000000000000000000000000026311d0000000000000000000000 Recv: 150b0000000000000005040000000000001b3d3e240300000000000000000000 Recv: 2c1d000000000000112b2e1500000000001f3637200200000000000000000000 Recv: 2f1e000000000000102d332a1200000002181f20110000000000000000000000 Recv: 1d11000000000000091e21201300000000060608040000000000000000000000 Recv: 0000000000000000000306070600000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: Recv: Pattern center [12.500000 14.500000], match 90.151512% Recv: Pattern center [13.500000 14.500000], match 91.666664% Recv: [13.236731, 14.455117][4.116258] final circle Recv: [219.721500 198.281270] mm pattern center Recv: xyzcal_meassure_leave [...] Recv: xyzcal_meassure_enter Recv: xyzcal_searchZ x=1206 y=19895 z=2094 Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=2094 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=2094 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1994 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1894 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1794 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=1694 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1694 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1594 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1494 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1394 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=1294 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1294 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1194 dz=100 radius=-900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=1094 dz=100 radius=900 ad=3 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=994 dz=100 radius=-900 ad=2 Recv: xyzcal_spiral8 cx=1206 cy=19895 z0=894 dz=100 radius=900 ad=0 Recv: xyzcal_spiral2 cx=1206 cy=19895 z0=894 dz=100 radius=900 ad=0 Recv: ON-SIGNAL at x=1225 y=19987 z=883 ad=100 Recv: Scan countdown: 64 Recv: 63 Recv: 62 Recv: 61 Recv: 60 Recv: 59 Recv: 58 Recv: 57 Recv: 56 Recv: 55 Recv: 54 Recv: 53 Recv: 52 Recv: 51 Recv: 50 Recv: 49 Recv: 48 Recv: 47 Recv: 46 Recv: 45 Recv: 44 Recv: 43 Recv: 42 Recv: 41 Recv: 40 Recv: 39 Recv: 38 Recv: 37 Recv: 36 Recv: 35 Recv: 34 Recv: 33 Recv: 32 Recv: 31 Recv: 30 Recv: 29 Recv: 28 Recv: 27 Recv: 26 Recv: 25 Recv: 24 Recv: 23 Recv: 22 Recv: 21 Recv: 20 Recv: 19 Recv: 18 Recv: 17 Recv: 16 Recv: 15 Recv: 14 Recv: 13 Recv: 12 Recv: 11 Recv: 10 Recv: 9 Recv: 8 Recv: 7 Recv: 6 Recv: 5 Recv: 4 Recv: 3 Recv: 2 Recv: 1 Recv: Recv: 0000040100000100000102000001010000010000000000000000000000000000 Recv: 0000030100000300000002000003020000010000000000000000000000000000 Recv: 000003000000030000020b040306020000030200000200000000000000000000 Recv: 1a00030000000200000d161c1611020000050f0f100e00000000000000000000 Recv: 1b0003000000020000142b2f2c19000000061b21211301000000000000000000 Recv: 1a0001000000010001203c463311000000001d32352103000000000000000000 Recv: 1a00010000000200001e3d452700000000001130331f00000000000000000000 Recv: 1a00010000000000000d2b2904000000000000141c0200000000000000000000 Recv: 1a00010100000000000000000000000000000000000000000000000000000000 Recv: 1900010000000000000000000000000000000000000000000000000000000000 Recv: 1a000100000000000000000000000d1316110200000000000000000000000000 Recv: 1900000000000000000000000629383b3c382702000000000000000000000000 Recv: 0000000000000000000000002340474546473d22000000000000000000000000 Recv: 0000000000000000000000023647454141454637080000000000000000000000 Recv: 1900000000000000000000123c46413b3c3f463b160000000000000000000000 Recv: 1900000000000000000000113b45413c3a40443d150000000000000000000000 Recv: 0000000000000000000000053244423f3f424331070000000000000000000000 Recv: 000000000000000000000000203b434343443a1d000000000000000000000000 Recv: 0000000000000000000000000221343a39301d00000000000000000000000000 Recv: 0000000000000000000000000000081212060000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000000000000000000000000000000000000000000000000000000000 Recv: 0000000000001723150000000000000000000000000000000000000000000000 Recv: 00000000000f3241300f00000000000000000000010000000000000000000000 Recv: 0000000000103244391700000000000000000000000000000000000000000000 Recv: 00000000000726312b1400000000000703000000000000000000000000000000 Recv: 0000000000001016120d0000000015251f060000000000000000000000000000 Recv: 0000000000000102000000000005212d2c140000000000000000000000000000 Recv: 00000000000000000000000000081b1f1d100000000000000000000000000000 Recv: 0000000000000000000000000001070405030000000000000000000000000000 Recv: Recv: Pattern center [15.500000 14.500000], match 87.121208% Recv: Pattern center [15.500000 14.500000], match 94.696968% Recv: [15.484080, 14.423905][4.243558] final circle Recv: [12.049811 198.261310] mm pattern center Recv: xyzcal_meassure_leave Recv: All 4 calibration points found. [...] Recv: Measured skews: 0.063761 -0.002032 [...]
Would appreciate your help a lot.
Thank you
Respondido : 12/04/2022 5:53 pm
