After Firmware update to middle
JohanN
(@johann)
I see that after every layer the printer is going to the middle.. i looked at the g code.. but that is not there...
example... print in the low corner... 1 layer... moving to the middle and back to the next layer.. and again tot the middle of the plate and back for the next layer..
what can that be???
gr
Johan
Veröffentlicht : 09/03/2023 1:20 pm
JohanN
(@johann)
https://forum.prusa3d.com/wp-content/uploads/2023/03/20230309_142405.mp4
see video
Diese r Beitrag wurde geändert Vor 3 years 2 mal von JohanN
Veröffentlicht : 09/03/2023 1:27 pm
René
(@rene-3)
RE: After Firmware update to middle
What printer do you have, and what firmware version did you use?
Which motherboard is in your printer?
There are six firmware versions.
Veröffentlicht : 09/03/2023 2:45 pm
JohanN
(@johann)
Sorry i3s+ and the latest firmware 3.12.2-5713
Veröffentlicht : 09/03/2023 5:04 pm
Tim Weston
(@tim-weston)
Can you post a zipped file with the .3mf project file and the generated G-code please? Then we can have a look at it.
Cheers,
Tim
Veröffentlicht : 09/03/2023 5:55 pm
René
(@rene-3)
Posted by: @johann
In that case it should be this one, right?
Veröffentlicht : 09/03/2023 7:11 pm
JohanN
(@johann)
Posted by: @rene-3
Posted by: @johann
yes that is the one
Veröffentlicht : 09/03/2023 7:48 pm
Ok I'm going to ask the obvious question that no has, are you printing from the SD card or from something like Octoprint ?
Veröffentlicht : 09/03/2023 7:52 pm
JohanN
(@johann)
The files
Veröffentlicht : 09/03/2023 7:54 pm
JohanN
(@johann)
Posted by: @neophyl
Octoprint
JohanN
(@johann)
I hope you see the files
Veröffentlicht : 09/03/2023 7:56 pm
Then please print a test print from the SD card.  I'm not usually a betting person but in this case I highly suspect that it wont do the centre move when printing from the sd card.
If it doesn't from the SD card then you need to go through all your octoprint settings.  Make sure you dont have anything like octolapse or similar running.
Every instance I've seen where the printer goes to a pre-set position on every layer has been down to Octoprint, usually when the user didn't realise they had octolapse running.
Veröffentlicht : 09/03/2023 8:04 pm
Tim Weston
(@tim-weston)
That's my bet too... 🙂
Veröffentlicht : 09/03/2023 8:06 pm
Cabezonfer
(@cabezonfer)
test
Veröffentlicht : 09/03/2023 8:13 pm
JohanN
(@johann)
The problem was the octolapse..  thanks... I also done a revo6 on my prusa but have some thermal issues.. and seems iam not the only one.. can't find a solution.. is there a solution on the latest firmware?
Veröffentlicht : 14/03/2023 10:21 pm
Not really no. Roll back to 3.11 firmware.
Veröffentlicht : 15/03/2023 6:06 am
