Z Lift on first and top ironing layer only
Rocky79
(@rocky79)
Hello,
How would I enable z lift on the first and a select top layer only?
I know I can enable Z Lift under printer retraction setting but it only allows a range above Z.
I currently have it set to only lift from 0 to 0.4mm but i also wanted to enable lift within an upper z height as well.( example Z lift from 0-0.4mm & 30-30.3mm)
Any idea how this could be done?
Thanks in advance.
Opublikowany : 17/02/2023 10:33 pm
