XYZ Calibration failures... on fresh out of box pre-assembled printer
brendan.g3
(@brendan-g3)
Understandably, I'm a little upset at present, I sent $250 extra to buy an assembled and tested printer... which doesn't seem to work.
This evening I pulled my new MK3 out of the box, followed the (rather out of order) instructions, powered it up to move the Z axis up (to make safe removal of the foam), removed the test print from the bed... then proceeded to run through the setup wizard.
First time I tried an XYZ calibration, I killed it quickly as the paper was getting caught by the nozzle, even poking a small needle sized hole through it.
Before the second time I got the nozzle nice & hot, removed the existing filament, and gave it a light cleaning. I could identify no further material sticking on the outside of the nozzle. It made it to failing on the second calibration point.
I noticed that one of the rear rubber feat was still in the box, so I put it back to where I thought it should go, along side the other rear foot on opposite rail. This time I made it to the third calibration point. An improvement? Not really.
For the fourth time, I broke out my camera to record the progress... and sure enough, come calibration point 2... it fails:
What am I supposed to do about this? The whole idea of buying a pre-assembled, pre-tested unit was to avoid these out of the box issues.
Order reference #: 182152226
On a lark, before posting this I decided to upgrade from firmware v 3.3.1-845 to 3.4. No changed, next failure happened on point 2... still catching the paper, despite the nozzle being clean. Before the upgrade I was getting "XYZ calibration failed. Bed calibration point was not found.", this last time around I'm told to consult the manual for the failure.
Postato : 20/09/2018 6:58 am
Olef
 Olef
(@olef)
Re: XYZ Calibration failures... on fresh out of box pre-assembled printer
No good venting on here I'm afraid, we are all just Prusa users. I have never seen a support reply via the forum.
Email your issue directly to [email protected] but expect 2 - 3 day wait for response, or use the live chat feature (bottom right) from https://shop.prusa3d.com
Sorry your journey started off badly but shipping can really mess up a printer. Contact support, they will sort you out. Good luck!
Postato : 20/09/2018 7:35 am
RH_Dreambox
(@rh_dreambox)
Use Prusa chat to get immediate answers.
It is located at the bottom right corner of this page.
https://shop.prusa3d.com/en/
Postato : 20/09/2018 4:29 pm
RufusClupea
(@rufusclupea)
Also be aware (if it wasn't in the documentation they sent you) that you'll likely have to recalibrate any time you move the printer, change nozzles, change build plates, and a few other occurrences that affect the printer physically.
It's just part of the game... 😐
when to recalibrate 3d printers
That's "MISTER Old Fart" to you!
Postato : 20/09/2018 5:36 pm
