Where is updated version of extruder-idler.stl?
ga
 ga
(@ga)
My i3 MK3S has an extruder-idler part with a hex hole, NOT a round hole, for the nut -- so it doesn't turn when the bolt is tightened.
The bolt on mine froze up in the nut somehow and couldn't be freed.  I had to make a jig to clamp the bolt against the spring to push the nut out far enough so I could cut it off.  However, previous attempts to unscrew the bolt had caused the nut to turn and destroy the hex hole.
I downloaded the MK3S parts and printed out a new pone, but the one in the parts .zip has a round hole.  Where is the one with the hex hole?
Thanks
Opublikowany : 12/09/2021 9:08 pm
ga
 ga
(@ga)
never mind...
I was looking at the back (inside) of the part.  Duh
Opublikowany : 12/09/2021 10:40 pm
