Which print bed sheet?
Neddy
(@neddy)
I'm thinking of buying the new Prusa i3 MK3S kit, but I'm not sure which print bed sheet I need, or if it's worth buying both?
I thinking I'll be using PETG and PLA for printing. PETG for functional parts, which is mostly what I want to print, and maybe a bit of PLA. (Does this sound right?)
Any advice on which print bed would be appreciated.
Cheers,
Ned
Best Answer by Mojo:
I would second Timo's answer.
The smooth PEI is the all arounder with generally good adhesion for most materials.
I only use the textured sheet when I need the special finish for optical reasons on a faceplate. Though, I experience, while adhesion for most materials is also good, PLA can be a gamble for longer prints.
Napsal : 08/08/2019 9:07 am
timo.m
(@timo-m)
RE: Which print bed sheet?
I would recommend you get both. I have had no issues with either of the beds but it is nice to have the choice if you wand a shiny or textured bottom surface. Also it is much cheaper to buy both of them now than buying one later with added shipping.
Napsal : 08/08/2019 10:04 am
1 lidem se líbí
Mojo
 Mojo
(@mojo)
This post was modified před 7 years by Mojo
Napsal : 08/08/2019 11:21 am
1 lidem se líbí
rmm200
(@rmm200)
I got both and like them both.
I will note I tried to add the second sheet during the sale purchase.
Adding anything other than the MK3S to the cart lost free shipping...
Bought the (cheaper) smooth sheet after. Maybe $12 shipping. Definitely worth it for PLA. Doubt if I will use it for PETG.
Napsal : 08/08/2019 3:18 pm
If you only buy one, go with the smooth. If you can, buy both.
Napsal : 08/08/2019 3:57 pm
stephen.h14
(@stephen-h14)
Last I looked, there was an option to buy smooth, textured, or both when you order a kit. Not sure when that was added but with the addition of sheet profiles in 3.8.0, it’ll be easier to swap between sheets!
This post was modified před 7 years by stephen.h14
Napsal : 09/08/2019 12:05 pm
Neddy
(@neddy)
Thanks for all the replies! I'll get both!
Also, it's awesome to see the community is pretty active and responsive.
Cheers
This post was modified před 7 years by Neddy
Napsal : 09/08/2019 11:29 pm
Neddy
(@neddy)
Just as a follow up, getting both sheets was definitely the right idea. I use the PEI sheet when printing PLA, and the textured sheet when printing PETG.
Cheers
Napsal : 06/09/2019 1:33 am
