weird failure on a large print
amiga-illume
(@amiga-illume)
odd error
Postato : 18/11/2022 3:50 am
amiga-illume
(@amiga-illume)
RE: weird failure on a large print
It seemed to drop my issue description. The fayers in the print jogged 2mm in the X axis for about 2mm of layers and then went back to the original. No errors in the slicing.
Postato : 18/11/2022 3:53 am
Make sure you r X axis toothed wheel is tight
Postato : 18/11/2022 7:46 am
The usual suspects are incorrect belt tension or loose grub screws on the motors. Another  possibility is that your nozzle hit infill or a perimeter that slightly curved upward. I've seen this quite often with grid infill that has overlapping lines of filament in a single layer.
Postato : 18/11/2022 12:36 pm
1 persone hanno apprezzato
Robin
(@robin)
Grub screw seems more likely than collision (since it shifted back to previous position)...
Postato : 18/11/2022 3:01 pm
amiga-illume
(@amiga-illume)
The drive belt is snug as well as the grub screw, there does not seem to be any lash in the x axis. I was going to replace the nozzle (other issues). any other suggestions?
Postato : 18/11/2022 6:16 pm
Mike Daneman
(@mike-daneman)
Are you printing through Octoprint?  I had a layer shift issue that drove me crazy for a long time printing through Octoprint. I then traced it to down to a specific plug-in and it resolved when I removed the plug-in.  Although in my case, the layer shift was just one way (i.e. it did not come back to normal on higher layers).
Postato : 28/11/2022 6:54 pm
towlerg
(@towlerg)
It seems very odd, to get a shift in a plane, print numerous layers and then shift back to exactly where it started.Is this a common fault?
Obviously not build plate adhesion. I can't imagine how, but does the Mk3 have some way to know this condition has occurred and correct it?
Postato : 29/11/2022 12:37 pm
