[Solved] Very Sensitive Power Supply
CodyHovland
(@codyhovland)
I had multiple prints turn off due to the power supply lightly getting bumped. Ill barely move the printer or bump the power supply and itll turn off. I paused a print to clean the nozzle and lightly touched the power supply and the unit turned off. Since it was paused the MK3s+ didnt offer to resume the print. Im in the middle of a 68 hour print and stopped 2/3rds of the way in. I'm so freaking pissed.
Has anyone experienced this or is the wiring in the power supply messed up?
Posted : 12/07/2022 4:06 pm
Tim Weston
(@tim-weston)
RE: Very Sensitive Power Supply
I had something a little similar when I first got my printer. Turned out that the mating of the mains plug and socket was not good. I changed to a different mains cable with a right-angled connector (happened to be the only one to hand) and all has been well since.
Cheers,
Tim
Posted : 12/07/2022 6:56 pm
CodyHovland
(@codyhovland)
I solved the issue! The plug was not plugged in al the way. I feel dumb but this is the hardest I've ever had to push to plug into a power supply.
Posted : 14/07/2022 9:47 pm
