Use your printer in an enclosure? - Prusa will void your warranty
stirlsilver
(@stirlsilver)
Hello everyone,
I just wanted to share an experience I just had with Prusa after I contacted them regarding deformation of a number of plastic parts on the hot end. I only print ABS so my setup is as follows:
  • Prusa i3 Mk3S
  • Lack Table enclosure (following the recommendations from here)
  • Internal enclosure temperature control at 41degC using a temperature sensor an air recirculation fan and extraction fan
  • Power supply unit relocated outside of the enclosure, Einsy inside the enclosure
after about a day of printing I found that the parts cooling fan shroud deformed and was starting to catch on prints, also the PINDA probe had sagged down slight and is now no longer sitting straight:
Anyway, I contacted Prusa support to tell them that I needed replacement parts. Only to be told that 40-45degC is too hot and that nothing will be replaced under warranty. I was pointed to the Prusa manual which said the operating temperature range of the printer is 18 to 38degC only.
You can't get reliable ABS prints with these temperatures, if you want to have decent large ABS prints you need to be at 40-45degC. How can they claim their printer is suitable for ABS printing?
Interested in what others think about my experience here...
If you are interested, email exchange with Prusa below:
I recently purchased and assembled the i3 Mk3S printer and I have put it to use printing ABS inside of an enclosure. Prints are usually with a hot end temperature of 245degC, bed temperature of 105 degC and an enclosure temperature of 40 to 45degC.
I have noticed a number of parts starting to deform on the printer. First it was the shroud for the part cooling fan, it deformed downwards and started catching on the prints, so I removed it. You can see in the photos below that it has been affected by the radiant heat from the hot end and partially melted.
Additionally, I've noticed that the holder of my PINDA sensor is now deforming and no longer sits vertically (photo below). What can be done to address these issues? And are other parts on the X carriage going to deform more over time?
Regards,
Stirling
Hi Stirling,
thanks for contacting us.
As the temp is really high inside the enclosure, I recommend the silicone sock for the heaterblock as this is able to shield the fan shroud a bit. Regarding the part with the PINDA holder, maybe if you're printing in this environment it would be good to print all the extruder parts from ABS/ASA to make it more heat resistant.
Just wanted to mention that the working temp for the einsy board is 45-50C max - so I'd recommend to use some cooling for the einsy board for sure.
Let me know if you need any further information and I wish you a nice day.
— Best regards / S pozdravem / Cordiali saluti
Pavla Šimůnková
Customer Support (en, cz, it)
Hello Pavla,
Thank you for your reply. To be honest your response to this issue is very worrying. ABS cannot be printed without using an enclosure because of warping, and the minimum ambient temperature you should use for printing this material is 40degC. So you are basically saying that the Prusa printer is not designed to print ABS? My colleague and I specifically chose Prusa printers for our business because they one of the best printers in the market, and not the cheapest.
For your information, I fitted the silicone cover on the heater block right when the printer was assembled. I did this myself as my own initiative to stop filament sticking to the block, the part wasn't included with the kit and the manual didn't suggest to fit it. So if you are recommending it, maybe it should be part of the kit?
I didn't print these parts myself, they were manufactured by Prusa as part of the kit. From my perspective, if the materials Prusa has used in the printer construction isn't capable of handling the heat it receives from the hot end, then this is a warranty issue and my expectation is that Prusa will be addressing it at no cost to me. Please note that https://www.prusa3d.com/material-guides/&source=gmail&ust=1576620490918000&usg=AFQjCNE7ZwNp3MsfU6H7xDC6poBQ_QT86 A"> https://www.prusa3d.com/material-guides/ shows all the materials the Prusa printer is compatible with and you will see that there are materials like ASA require an extruder temperature much hotter than what is needed for ABS.
For your information, my colleague experienced the same issues and contacted Prusa a few days earlier and he has had replacement parts sent to him. I am expecting the same.
Regards,
Stirling
Hi Stirling,
the ABS can be printed  - for example with skirt all around the print. It is designed for ABS and ASA, the enclosure is optional and it is not supplied by us, but unfortunately the working temp for the board is max 40C (it can withstand higher temps for some time, but we cannot guarantee how long of course and we cannot even guarantee the plastic parts can withstand it) - as we have mentioned in the https://prusa3d.com/downloads/manual/prusa3d_manual_mk3s_en_3_10.pdf%23_ga%3D2.185951786.2022422896.1551340285-1501600604.1549756165&source=gmail&ust=1576620490928000&usg=AFQjCNFJJY1uD2D_hWZc8lNOQV77qVNqB A">Handbook as well, maximal humidity is 85% or less (please note working range for the printer is specifically mentioned to 18 -38C and indoor use only).
So, without the enclosure which is not supplied by us you must get under those specs - ABS needs more than higher temp stable temp.
Previously we were thinking about the silicone sock, but in the end we made it optional  - up to the customer.
Unfortunately as the working range is higher in your case, we cannot take it under warranty.
Pavla Šimůnková
Postato : 16/12/2019 10:52 pm
rmm200
(@rmm200)
RE: Use your printer in an enclosure? - Prusa will void your warranty
If I was Prusa I would not replace printed parts either from being used in those conditions.
If you want to print ABS - get the appropriate parts printed in PC or some other high temp material.
It is not that expensive.
Postato : 17/12/2019 6:58 am
1 persone hanno apprezzato
stirlsilver
(@stirlsilver)
@robert-rmm200
Thanks Robert, is really 40-45degC that hot for an enclosure printing ABS? Here in Australia we get that temperature outside and all electronics are rated for such conditions.
For the fan shroud, the main source of heat is the bed when printing the first layer. That surface is 100-105degC plus radiant heat from the heater block (and I had a silicone cover on). I doubt having an enclosure 2 to 7 degrees warmer than the rated 38degC maximum would cause this? Then consider the case where printing ASA - the nozzle temperature needs to be 260degC, that's worse again beyond the small increase in enclosure temperature I am using.
Surely I can't be the only person that has experienced deformation of these parts and thinks that Prusa should do better with the material selection?
Thanks,
Stirling
Questo post è stato modificato 6 years fa da stirlsilver
Postato : 17/12/2019 7:23 am
Nikolai
(@nikolai)
PR could have offered ABS parts in this case. I also think it‘s confusing advertisement. Saying on the one hand ABS material can be used and on the other hand the requirements for ABS printing are actually not fully met. Room for improvements in customer service.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 17/12/2019 8:53 am
Protoncek
(@protoncek)
Not that i agree with Prusa support, but wouldn't be quicker and easier just to print this part by yourself? I know that i would certainly do that - STL's are available, so i don't see any problem. And if you mostly print ABS print it with ABS, not PETG.
I think that main problem is that when printing ABS cooling fan is mostly OFF, so this shroud doesn't cool itself as it is with PLA and PETG.
Postato : 17/12/2019 1:28 pm
stirlsilver
(@stirlsilver)
@protoncek
Yes, absolutely I can print this myself but that isn't really the point. My problem is, Prusa advertises their printer as being suitable for ABS printing, but it really isn't. That's false marketing, and I would like them to acknowledge that and address it so others don't end up in this situation.
The fan shroud isn't really an issue for me. I can just replace that easily. The deformation of the PINDA sensor bracket is another story. I have to pull half the extruder assembly apart, something that I wouldn't have to do if Prusa made the part from the right material to begin with.
Thanks,
Stirling
Postato : 18/12/2019 12:01 am
natehansen66
(@natehansen66)
@stirlsilver
I had the same issues and ended up printing all my extruder parts in pc. My PINDA got really droopy. I would think that with a machine with an E3d hot end capable of 300c print temp that the extruder parts would come in a material suited for higher temp printing.
Postato : 22/12/2019 4:04 pm
Peter M
(@peter-m)
Search forum for the max temp for E3d, this is i think 30 or 35 degrees, around the extruder.
In enclosure should not exceed 30 or 35 degrees.
Higher temp then cooling will not work very good, especially in the summer.
Maybe try to leave enclosure a little open, if room does not have a draft, or is to cold.
MK3 is made without enclosure so if you use a enclosure there is a compromise.
Make parts with higher temp filament.
Postato : 24/12/2019 5:47 pm
Posted by: @peter-m26
I've found a reference that the E3D V6 hotend is rated to 40C ambient. Any higher and the air-cooled design loses efficiency in cooling. Usually only a problem with filaments that soften at low temps like PLA, but still worth noting, not to mention that the electronics don't like the heat.
I think Prusa may have added to the misery by publishing the Lack enclosure blog entry back in 2018. This was early in the year, and of course, that was the summer of the extruder clicks & jams. The blog was taken as "official" and a lot of people built them for looks rather than understanding the implications.
Postato : 24/12/2019 6:01 pm
Nikolai
(@nikolai)
@peter-m26
We had no issues in regards to that with MK2. The parts were printed in ABS. Once Prusa switched to PETG for all parts then we started to see issues with printers without the sock.  I consider that as one of the quality decreases we got with MK3.
Often linked posts:
Real Multi Material
Postato : 24/12/2019 7:25 pm
Skewed Perception
(@skewed-perception)
I've had the same issue with my MK3S (sagging fan shroud and part of extruder-body/cover near PINDA holder) although I have never used an enclosure - merely printed with higher temp materials, but always within printer specs. So the enclosure can not be the culprit here; these parts fail even without using one.
Prusa should replace those parts for you at the very minimum. They should make the extruder plastic parts out of polycarbonate so they actually withstand the temperatures. I've replaced my fan shroud with a PC print and it appears to work better.
Questo post è stato modificato 6 years fa da Skewed Perception
Postato : 26/12/2019 12:05 pm
vintagepc
(@vintagepc)
Utenti
Even with a sock I was suffering fan shroud deformation (Stock and skelestruder designs) I've reprinted in ABS and it seems to be holding up much better so far.
Postato : 26/12/2019 1:48 pm
Lichtjaeger
(@lichtjaeger)
Posted by: @vintagepc
Prusa's official statement:
Note that this part can't be printed from PETG, but at least from ABS or Polycarbonate as it has to sustain high temps.
See here.
Postato : 26/12/2019 3:39 pm
rmm200
(@rmm200)
Well from the referenced document on the MK3 to MK3S Upgrade kit, "Fan-shroud (printed from ABS and included)".
Sounds to me like if you bought any flavor of MK3S, you should get the ABS fan shroud.
Worth chatting with CS about. (Still easier to print your own, but whatever).
Postato : 27/12/2019 5:12 am
Ben
 Ben
(@ben-4)
That's too bad.  I have the MK3s upgrade that shipped with the MMU2.  I have just finished printing a lot of ABS using the lack enclosure as well.  I do not control the temperature within, just shut the doors.  I use the Prusa ABS filament profile with no changes.  My hot end looks like no high temp damage and the PINDA is OK as well.  My ambient is typically around 70F.
Maybe there is something else about your setup that caused the high heat?
Postato : 27/12/2019 8:51 pm
rmm200
(@rmm200)
Somewhat related question: Is there any easy way to tell what the fan shroud is made of?
Specifically - how do you know if it is currently ABS.
Postato : 27/12/2019 9:13 pm
vintagepc
(@vintagepc)
Utenti
Just to clarify - I did get an ABS fan shroud with my upgrade kit, but I was running custom extruder designs to work around the optical filament sensor problems and did not have any ABS to print with. PETG holds up okay if you're only doing PLA, but as soon as you deal with PETG bed temps it deforms too much.
Postato : 27/12/2019 10:18 pm
