TPU Polyurethane
I have a spool of Duramic TPU that I am planning on using to print a glass cushion. I can't find any filament profiles for this type of material though it seems common. Any ideas or comments before I forge ahead?
Veröffentlicht : 08/06/2022 7:09 pm
RE: TPU Polyurethane
Start with the Generic Flex profile and go from there. Make sure you loosen the idler screw so that it's just barely catching. And if you like your steel sheet, put glue stick, Magigoo, Layerneer or some other separating agent on.
Veröffentlicht : 08/06/2022 8:38 pm
Thanks Fusher I will follow your advice. I will use glue stick on the bed cover. I was planning on using the textured, powder coat bed with glue stick.
-Brad
Veröffentlicht : 08/06/2022 9:24 pm
The satin sheet works good with tpu
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Veröffentlicht : 11/06/2022 3:40 am
