The First Layer of Supports Is dragging/not sticking
Dawson
(@dawson-2)
I am trying to print a fairly small and simple table spinner type-thing. (The thing from Inception). I may have overdone the supports, but whenever the first layer of the supports prints it either curves up on the edges or completely fails and does not stick.
I have tried every type of factory reset and calibration there is. I've tightened all the belts and washed the bed with dish soap once in a while and isopropyl alcohol before every print. It seems like there is no surface adhesion at all
Veröffentlicht : 26/01/2021 3:05 am
RE: The First Layer of Supports Is dragging/not sticking
What material are you printing? If the bed is indeed clean, Live Z would be the first think I'd check and lower until I get adhesion.
Veröffentlicht : 26/01/2021 12:04 pm
Peter M
(@peter-m)
Clean bed with dish soap. use hot water, use a lot of water, clean several times.
The print  a few squares, so you can adjust the z layer for every square different.
Then start to high with the z layer, then lower for every square.
Veröffentlicht : 26/01/2021 1:16 pm
Dawson
(@dawson-2)
@fuchsr
I've adjusted live Z many times but I might try @peter-m-3's method to get it further adjusted
Veröffentlicht : 26/01/2021 1:20 pm
@dawson-2
This is how I do it:
but I use a smaller square and change the Live Z 3 or 4 times per square, not just on the diagonal.
Actually, I use the standard Prusa first layer calibration to just get to the point where my filament sticks, then I use jeffjordan's approach to fine tune it.
Veröffentlicht : 26/01/2021 1:25 pm
Peter M
(@peter-m)
In the printer settings , set it to 7x7 calibration.
Veröffentlicht : 26/01/2021 1:41 pm
Dawson
(@dawson-2)
I had the print was going very well for a relatively long time.  Just now the nozzle randomly crashed into it. Any tips about that or is it just a weird mistake?
Veröffentlicht : 26/01/2021 4:04 pm
