[Résolu] Sudden issue with bed leveling / calibration
Dave
 Dave
(@dave-22)
Hi.
I've been having no problems and everything has been well as I've clocked up many hours of successful printing since building my kit about 6 months ago.
Then this morning, I suddenly had an issue with my print failing apparently due to a crash. Cleaned everything up and tried again but Octoprint kept reporting "Excessive Bed Leveling correction: 2700 microns".
My friend Google told me to run the calibration again (not the first layer calibration but the full calibration) which I did properly with the sheet off and paper on - when it comes to the Z axis, it works for points 1 and 2 of 4 (i.e. the front left and front right) but when it goes to point 3 (back right) it fails and reports bed calibration point not found.
I've checked the PINDA sensor is working and I rotated both sides manually hard against the top so that the z axis was definitely being calibrated level but still no good.
The only references to this I can find relate to new build teething problems rather than a sudden fault with an established working machine. Because of that, I wanted to check here before I start taking it all apart. Does anyone have any ideas?
Thanks,
Dave
Publié : 24/02/2021 8:55 am
RE: Sudden issue with bed leveling / calibration
Make sure there is nothing, not even a whisker of stringing, under the steel-sheet or stuck to the back.
Hth, Cheerio,
Publié : 24/02/2021 10:02 am
Clarmrrsn
(@clarmrrsn)
Just a stab in the dark here but if nothing under the bed make sure none of your frame bolts or y axis rod holders are loose.
Could be movement somewhere.
Tank you very much!
Publié : 24/02/2021 11:15 am
Membre
Also, make sure one of your screws on your bed is not elevated.
Publié : 24/02/2021 11:28 am
Dave
 Dave
(@dave-22)
Thanks for all the good advice everyone. Much appreciated.
In this case it was indeed debris but not where implied by the error message. It was actually wrapped around the y-belt motor cog which was creating some weird gearing effect so that plate was moved too far. This meant that, when point 3 was being calibrated, it was trying to do it partly over thin air.
My advice to anyone that finds their way to this forum thread because of a similar error is therefore to also run Belt Test in the Calibration menu. Not because it is the most likely but because it is a quick and easy elimination.
Cheers.
Dave
Ce message a été modifié il y a 5 years par Dave
Publié : 24/02/2021 3:55 pm
