Strange noises - what could it be?
Jan Pätzold
(@jan-patzold)
Hello,
my printer makes very strange noises. Have a look at the attached video. Do you know what that can be... Is that normal?
Do you have any ideas?
I am looking forward to your answer.
Strange Noises
Many greetings
Jan
This topic was modified 7 years temu 2 times by Jan Pätzold
Opublikowany : 16/08/2019 7:19 pm
RyanG
(@ryang)
RE: Strange noises - what could it be?
Sounds like a Bondtech gear grinding on its axle or something.... More like metal-on-metal than just filament being ground down. Or maybe something else metal out of alignment or loose?
Opublikowany : 17/08/2019 3:36 am
Maybe there is something with the filament transport gears. Open the extruder on the right side and look for broken or loose components. In worst case disassemble it.
Opublikowany : 17/08/2019 3:47 am
My vote goes for the Bondtech gears and roller bearings not greased; and perhaps the idler axle is pushed out of one of the ears allowing the idler to grind plastic.
Opublikowany : 17/08/2019 4:34 am
