Strange 1st layer artefact?
Not_Dave
(@not_dave)
what’s causing this? The very short little wiggle lines, it seems to be worse on some filaments than others. Sometimes it’s not there at all and prints a perfect 1st layer. Any ideas?
This topic was modified 4 years temu by Not_Dave
Opublikowany : 05/04/2022 8:19 pm
RE: Strange 1st layer artefact?
That’s a symptom of being very slightly too close to the build plate. It’s pushing the already extruded filament around. You sometimes have to tweak your live z value for different filaments. Just one of those things.
Opublikowany : 05/04/2022 10:13 pm
hawai
(@hawai)
I had a similar issue recently...
Apart from the too low z, have you used the culprit filaments before or are you new to them?
I had a batch that came already quite moist and I had to dry it multiple times. It didn't do the quality any good and I assume that it became very uneven over time. This resulted in a wavy pattern as well. My culprit also became extremely brittle. Very nice looking calibration squares split along the lines after a few days.
jm0.02$
Opublikowany : 13/04/2022 4:58 am
